Is this NA6 CAS dead?
Posted: Tue Apr 30, 2013 6:51 pm
Its not installed in a car, so I’ve tested it as per these instructions:
http://www.rivercityroad.com/garage/cas_testing.htm
Using two 10k resistors to pull the two outputs up to 5volts from a small switchmode power supply.
With the CAS powered up (12volts to the second pin as per the photo in the link), the outputs are always tied to ground, no matter the rotation of the CAS.
(when turning the CAS there should be 2 5volt pulses per revolution for one output, and 4 pulses for the other)
Disconnect the 12volts, and the outputs go up to 5volts
SO, the two transistors on the outputs are functional, however, the optical sensors appear to be dead.
Any suggestions? or confirmation that it is dead? thanks!
