Short nose loctite fix
mewse
Postby mewse » Wed Apr 17, 2013 5:02 pm
Hey guys,
im going through and replacing all seals and gaskets before i put the old engine (short nose na6) into the new car and with great fear i pulled of the timing gear to find the keyway perfect :D , not a single sign of the dreaded keyway wear but im just curious should i go ahead and do the loctite fix just to be on the safe side or would it be better to just leave everything as is and put it all back together?
"HA! I could be an electrical engineer, wait, why is that smoking?"
Re: Short nose loctite fix
Postby manga_blue » Wed Apr 17, 2013 5:47 pm
If it's all good then all you need to do is use normal loktite 243 or 262 "threadlocker" on the main bolt and loktite 609 "shaft fit" (also called cylindrical bonding retaining compound) on the key, nose and inner pulley faces. The 609 is not a repair compound and it's not strictly necessary either, but it's good insurance.
JBT
Postby JBT » Wed Apr 17, 2013 5:51 pm
It's worth getting a new bolt too.
Postby manga_blue » Wed Apr 17, 2013 5:53 pm
^ x2, and also doing a really good clean of the threads inside the crank nose.
mewse
Postby mewse » Wed Apr 17, 2013 6:11 pm
Thanks for the info guys i will get on that tomorrow only issue im having now is the crank seal has just fallen to pieces and is proving difficult to get out
mewse
Postby mewse » Thu Apr 18, 2013 6:11 pm
Nevermind upon lots of swearing and abuse we got the seal off
Users browsing this forum: No registered users and 27 guests
