nb to na clutch & flywheel swap
fcruz3r
Postby fcruz3r » Tue Apr 16, 2013 7:01 pm
hey all,
recently purchased a HD clutch kit for a 1990-93 1.6NA and was going to buy a lightened chromo 1.6 flywheel and swap over all these to my nb8a. Question I got is whether all the 1.8 flywheel & pressure plate bolts etc are re-usable to fit the NA one on my car?
just don't want to have dropped the gearbox only to realise that I needed all these other tiny bits to make it fit.
Boyracer
MX-5 Encyclopedia
Re: nb to na clutch & flywheel swap
Postby Boyracer » Wed Apr 17, 2013 1:52 pm
Everything is interchangeable NA and NB as long as its a 1.6 clutch on a 1.6 flywheel and so on.
fcruz3r
Postby fcruz3r » Wed Apr 17, 2013 2:45 pm
thanks mate. I guess my question is more whether i can re-use the existing pressure plate bolts and flywheel bolts from the 1.8 NB
I've got/getting the following
1. NA6 1.6HD clutch kit...which would have the pp, disk and throwout bearing
2. NA6 lightened flywheel (new FW only, no bolts included)
3. spigot bearing
4. rear main seal (for nb)
so basically i need to know whether i'll have the right number of pressure plate bolts, flywheel bolts to make this a straight forward swap? mainly concerned because from the pics I've seen, the na6 flywheel is flat and the nb flywheel have raised pp mount points...so the bolts may be too short / long / less / more?
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Wed Apr 17, 2013 3:14 pm
Bolts should be all the same.
project.r.racing
Postby project.r.racing » Wed Apr 17, 2013 6:39 pm
Bolts are the same.
fcruz3r
Postby fcruz3r » Wed Apr 17, 2013 7:29 pm
thanks ^^
That's one less thing to worry about stuffing up when I attempt to do this.
tbro
Postby tbro » Wed Apr 17, 2013 7:50 pm
If your buying a TODA flywheel, then the pressure plate bolts won't fit.
From memory ( memory me ha ha) the std bolts are 8x1.25, you need 8 x 1.5 x 15 or visa versa.
Your welcome :) :)
Terry
fcruz3r
Postby fcruz3r » Wed Apr 17, 2013 8:23 pm
no, F1 Racing flywheel from goodwin.
Darn...better check just in case coz they look like TODA knock-offs
Users browsing this forum: No registered users and 42 guests
