Misfire Under sudden acceleration
mewse
Postby mewse » Sun Apr 07, 2013 12:10 am
Hey guys,
Im still very new to mechanics and automobiles so sorry for my terrible explanation and lack of knowledge. So ive just bought my second mx5 (89 aus na) after the first had a mishap with a tree, as far as i knew although the little white rocket looked a little rough the engine still ran fine but upon getting it all back together it starts and idles fine and if im very gentle it will rev through just fine but if i push the throttle suddenly it misfires and then splutters and starts to rev, it makes the car undriveable.
So far the list of things ive checked are plugs and leads, fuel filter, TPS, AFM and the timing is correct and im at a loss and any help will be greatly appriciated.
"HA! I could be an electrical engineer, wait, why is that smoking?"
project.r.racing
Re: Misfire Under sudden acceleration
Postby project.r.racing » Sun Apr 07, 2013 8:29 am
see misfire thread 3 below this.
Postby 93_Clubman » Sun Apr 07, 2013 12:34 pm
mewse wrote:just bought my second mx5 (89 aus na) as far as i knew although the little white rocket looked a little rough the engine still ran fine but upon getting it all back together it starts and idles fine and if im very gentle it will rev through just fine but if i push the throttle suddenly it misfires and then splutters and starts to rev, it makes the car undriveable. So far the list of things ive checked are plugs and leads, fuel filter, TPS, AFM and the timing is correct
Sounds like you've dismantled part/s of the car. How was it running prior to dismantling? Is it possible something you've done in dismantling & reassembling has caused this issue? When you say you've checked the spark plugs & spark plug leads, have you tried swapping in known good plugs & leads? On the NA6 it's usually plug leads &/ or coilpacks. Alternatively, does the issue persist once the engine has warmed up? The coolant temp sensor at the rear of the head for the ECU & cold starting is also a common issue. This causes poor cold running that clears up once warm.
mewse
Postby mewse » Sun Apr 07, 2013 1:51 pm
The only things i has dismantled is the headers and exhaust as this car come without any, i put in working plugs leads and the coilpack from my old car today and still no change having the car at operating temp doesnt seem to make any difference either
emily_mx5
Postby emily_mx5 » Sun Apr 07, 2013 4:53 pm
do you have an exhaust leak? if there is a really bad leak up near the headers/cat, it can mess with the O2 readings and cause your symptoms.
mewse
Postby mewse » Sun Apr 07, 2013 6:18 pm
emily_mxV wrote:do you have an exhaust leak? if there is a really bad leak up near the headers/cat, it can mess with the O2 readings and cause your symptoms.
I think i may have a exhaust leak at the joint between the headers and the exhaust but the o2 sensor is before that so i didnt think that would matter, although my exhaust has a second o2 sensor in it but i couldnt find anywhere for it to plug in?
emily_mx5
Postby emily_mx5 » Sun Apr 07, 2013 7:06 pm
yeah an exhaust leak anywhere can mess up a quite a few things, definitely get it checked out, maybe you need a new gasket or a hole welded up.
ummm 2 oxy sensors? thats not stock. Do you mean a little sensor that plugged into the original cat? if so that is a temp sensor. If its just hanging around under the car, unplug it.
this is my custom cat with the oem sensor port welded in.
mewse
Postby mewse » Sun Apr 07, 2013 7:38 pm
im hoping its just a gasket as i half assed it and just reused the old one, and that looks exactly like the sensor i mentioned thanks for clearing it up and sorry for my ignorance haha
mewse
Postby mewse » Mon Apr 08, 2013 7:20 pm
Fixed the exhaust leak today and still no change, any other suggestions of what might be causing my issues? Would it help if i uploaded a video of it?
spikey
Postby spikey » Sun Apr 14, 2013 12:27 am
Try unplugging the oxy sensor, if that fixes it then it is your sensor that is faulty.
mewse
Postby mewse » Sun Apr 14, 2013 1:38 pm
spikey wrote:Try unplugging the oxy sensor, if that fixes it then it is your sensor that is faulty.
Just tried that still no change :? ive also swapped injectors, fuel pressure reg, fuel pump with known working one and still nothing, im out of ideas.
Steampunk
Postby Steampunk » Sun Apr 14, 2013 1:51 pm
Check all the pneumatic hoses, you may have a vacuum leak.
Did you clean the AFM connection?
What did you check re AFM? Does the flap move freely?
I doubt a leaky exhaust causes this kind of hesitation, unless the leak is really early on in the primaries and it'll have to be pretty darn close to the flange to affect anything.
The car should still drive ok with a faulty/non-existent O2 sensor, try unplugging it completely.
Postby 93_Clubman » Sun Apr 14, 2013 2:08 pm
93_Clubman wrote:
mewse wrote:it starts and idles fine and if im very gentle it will rev through just fine but if i push the throttle suddenly it misfires and then splutters and starts to rev, it makes the car undriveable.
mewse
Postby mewse » Sun Apr 14, 2013 2:46 pm
Steampunk wrote:Check all the pneumatic hoses, you may have a vacuum leak.
I've checked the hoses and could not find a vac leak but i will check again, i haven't cleaned the connector for the AFM but i did swap it out for my known working one off my old car. Also the car behaves exactly the same regardless if it is cold or at running temp
Postby 93_Clubman » Sun Apr 14, 2013 2:58 pm
mewse wrote:Also the car behaves exactly the same regardless if it is cold or at running temp
ok - check ECU PCB for any discoloration or other obvious signs of an issue, also check earthing points.
Users browsing this forum: No registered users and 51 guests
