Question about the little green cap
- Learner Driver
Does anyone know what the aqua green cap like plug sitting on aluminium pipe does? It's located to the rear right side of the motor and has an 'H' on it.
- Learner Driver
Re: Question about the little green cap
Lol? Not sure what you mean. Stupid question? Knocked the cap off but pin remains. Any urgency in having it repaired/replaced?
- TieNN89
So the cap is removed?
It'll be alright, I didn't have caps on mine when I bought my old MX-5 but they stuck caps on it after I got the aircon re-gassed
It's just where they hook there hoses up to re-gas your aircon
- Learner Driver
The cap itself has snapped off but the end of it remains in the cavity. I love this forum!
ok i will elaborate for you.
The actual plastic cap is just a cap. it screws onto the piping. it is just a cover.
Underneath is a valve. If this valve is pressed very very toxic gas will be released.
Its also really bad for the environment. If you loose to much your A/C system won't work anymore.
So the cap doesn't directly do anything, it just protects the valve.
I would try to get another one, wouldn't be too expensive.
- Learner Driver
Thanks for the elaboration, most helpful. Stay tuned for the next novice question
- TieNN89
Ah yeah same situation as I was in. Cap snapped off but the thread part was still in there.
I wouldn't worry about it which I wasn't at the time
Just wait till you need your air con regassed and get them to stick new caps on if they don't
- Learner Driver
Took a trip to see Dick at mx5 factory. Cap replaced no worries plus some other helpful tips besides. Thanks for all the info. First time owner of this car as of 5 days ago, not mechanically minded.....yet! This forum has been a huge source of information so far.
One of mine snapped off leaving part of it still attached to the valve so I just glued it back on again...don't know how long that will last...
