Difference between JDM NC engine and the Australian delivery
Posted: Wed Mar 20, 2013 1:02 pm
by as_1
This may have been asked before
What's the difference? Why does their's pull out 125kw and ours 118kw?
Re: Difference between JDM NC engine and the Australian deli
Posted: Wed Mar 20, 2013 1:55 pm
by vrmmmpshhh
Their high-oc fuel is 100 not 98 from memory.
Posted: Wed Mar 20, 2013 3:44 pm
by sailaholic
Mazda de rates for our fuel. The new sp20 sky active 3 has lower compression to be run on 91 instead of 95.
Posted: Wed Mar 20, 2013 7:14 pm
by Zcootz
So am I wasting my $$$ running premium into NB8a ?
Posted: Wed Mar 20, 2013 7:25 pm
by project.r.racing
use higher octane fuel, adjust timing, get same result as JDM.
Posted: Fri Mar 22, 2013 9:24 am
by as_1
project.r.racing wrote:use higher octane fuel, adjust timing, get same result as JDM.
what's timing?
Posted: Fri Mar 22, 2013 3:23 pm
by emily_mx5
... Not sure if serious ?
Posted: Fri Mar 22, 2013 6:36 pm
by Zcootz
I hope not....
Posted: Fri Mar 22, 2013 6:53 pm
by Apu
as_1 wrote:project.r.racing wrote:use higher octane fuel, adjust timing, get same result as JDM.
what's timing?
Timing is what you worry about before you get married.
Posted: Fri Mar 22, 2013 8:22 pm
by Steampunk
as_1 wrote:what's timing?
it's 8:22pm
Posted: Fri Mar 22, 2013 8:30 pm
by as_1
i'm being serious lol
Posted: Fri Mar 22, 2013 9:19 pm
by KevGoat
Thought one couldn't change the timing on NB's onward due to ECU/knock sensor and then VVT on the later models? ....
Posted: Fri Mar 22, 2013 9:24 pm
by NitroDann
You can change anything with man performance parts.
Posted: Sat Mar 23, 2013 11:42 am
by little decks
as_1 wrote:i'm being serious lol
Rather than anyone explaining it, just google ignition timing, but its pretty much about changing the point in the stroke at which your spark ignites your fuel
Posted: Sat Mar 23, 2013 11:58 am
by 93_Clubman
KevGoat wrote:project.r.racing wrote:use higher octane fuel, adjust timing, get same result as JDM.
For NB use one of these:
http://forum.miata.net/vb/showthread.php?p=5925040
