Fuel Tank Crack
ishotabear
Fuel Tank Crack
Postby ishotabear » Mon Mar 11, 2013 10:33 am
Hi guys, I've got a question regarding the NA fuel tank. I noticed a leak a week ago in an awkward spot, so I pulled the tank out and found a small crack that had been repaired before with the epoxy tank repair stuff. I plan on getting this crack professionally repaired or tracking down a second hand fuel tank.
I was just wondering if this area might be a high stressed point in the tank? Could a repair job flex and crack again? It looks like something's bashed into it and caused the crack but I want to be sure it won't happen again!
If anyone's got a fuel tank lying around they're looking to get rid of, I am interested. Cheers!
EDIT: Didn't realise pics were broken!
spikes
Re: Fuel Tank Crack
Postby spikes » Mon Mar 11, 2013 12:31 pm
The fuel tank isn't a stressed member of the chassis. Depending on the quality of the repair, you should be fine
ishotabear
Re: Fuel Tank Crack
Postby ishotabear » Mon Mar 11, 2013 12:34 pm
Brilliant I'll take it to a shop this week. I just don't want it to crack again because taking it out is such a pain!
spikes
Re: Fuel Tank Crack
Postby spikes » Mon Mar 11, 2013 2:39 pm
How was it damaged? The fuel tank in an MX5 is pretty tucked away, doesn't get damaged easily
ishotabear
Re: Fuel Tank Crack
Postby ishotabear » Mon Mar 11, 2013 3:25 pm
I'm not sure how it happened, It was already cracked when I got it, there was some epoxy crap covering it up. I smelled petrol and checked under the car and there it was :(
gslender
Re: Fuel Tank Crack
Postby gslender » Mon Mar 11, 2013 4:32 pm
If it has been repaired, it is possible the pump been out before, and possibly the seal isn't too great, so you might wish to check that too.
G
ishotabear
Re: Fuel Tank Crack
Postby ishotabear » Mon Mar 11, 2013 5:10 pm
I'll make sure to check that out before it goes back in, thanks! I didn't have any fuel troubles before, at least until the crack appeared, so hopefully all is well. I've had the car for a couple of years now.
