Onboard Diagnostic codes
- dbr
- Vehicle: NB8A - Turbo
Does anybody have the definitions for the diagnostic codes (number of flashes) of an Australian NB8a? My manual is for an american spec. which has OBD2.
Re: Onboard Diagnostic codes
Did they just keep using the NA codes?
http://www.miata.net/garage/Engine_Diagnostics.html
manga_blue wrote:Did they just keep using the NA codes?
Good question - not sure, but codes are apparently in the manual link in the following post:
viewtopic.php?f=29&t=44626&p=565430#p565430
- dbr
Thanks.
Gennerally, manufacturers added to their diagnostic code list for the new features of subsuquint modles, so the NA list is a good start.
I didn't have much luck with the manual links, but thanks anyway.
Caff posted these for his early (pre OBDII) NB8B:
viewtopic.php?f=18&t=16872
NA6 & NA8:
http://www.miata.net/garage/faultcodes.html
Caffeine wrote:These are the codes:
Code Meaning
1 Ignition pulse
2 Ne signal
3 G signal
4 SGT signal (1.8L)
8 Airflow meter
9 Water thermistor
10 Intake air thermistor in airflow meter
12 Throttle position sensor
14 Atmospheric pressure sensor
15 Oxygen sensor (output too low)
16 EGR function sensor (1.8L)
17 Oxygen sensor (output not changing)
25 PRC solenoid valve (1.8L)
26 Solenoid valve (Evaporative canister purge)
27 EGR solenoid valve (vacuum)(1.8L)
28 EGR solenoid valve (vent)(1.8L)
34 34 Idle air control (1.8L)
36 Idle speed control valve
NA6 & NA8:
- dbr
thanks
- ckwan028
Sorry, Dragging out an old post....
I had just performed a diagnostic.. and the code is:
long long short
long long
long long short
long long
long long short
long long
long long short
So I believe the code is 20 and 21.
However, 20 and 21 wasn't mention on the code list.
Anyone can help?
Thanks
long long short
long long
long long short
long long
long long short
long long
long long short
Anyone can help?
Thanks
Milky
I read somewhere that the first long flash for each error is ignored, & this video
seems to back that up:
http://www.youtube.com/watch?v=cFqVJ4uaurw
That means your error codes are 10 & 11, BUT 11 is not on list either ?
My question is what do SGT (code 4) & PRC (code 25) stand for ?
Users browsing this forum: No registered users and 68 guests
