Mild cams on standard ecu and exhaust NB8A
Posted: Mon Jan 21, 2013 10:16 am
I'm looking at checking the valve clearances on my stock NB8A, and with the possibility of having to take the cams out to replace shims I'm thinking about slipping in a new set of cams while I'm there to give the motor a bit of a freshen-up. If its possible to get a bit of additional mid range shove without doing cam gears, ECU, exhaust etc....with some mild cams such as Tighe 708C's, or would any gains be too small to notice without doing all the extra mods? I have read that some have had good results with 805C's but they were in tandem with ECU etc....With the 708C's being less aggressive I'm wondering it it would be worth the expense. If anyone has done it I'd like to hear from you.
