Throttle body sensor NB 2001
Divo
Vehicle: ND - 1.5 GT
Postby Divo » Sun Jan 20, 2013 10:56 am
Hi
The underneath of the TB sensor has a vacuum outlet which connects to where?
I've got an NB in a clubman and can't find where it should connect to.
Re: Throttle body sensor NB 2001
Postby 93_Clubman » Sun Jan 20, 2013 11:34 am
Just had a look at a 1999 NB8, but TB is different by the sound of it.
If the 2001 NB8 TB is like the 1993-1995 NA8 TB, then there's a 3/4" diameter air pipe which goes to the black plastic intake pipe which runs across the front of the motor (1999 TB doesn't have this). Btw, NA8 motor won't run with this pipe disconnected from intake & just sucking air.
project.r.racing
Postby project.r.racing » Sun Jan 20, 2013 1:57 pm
the TPS is the only sensor that is attached to the throttle and it has no lines connected to it.
both have a idle air controller, the na8 version comes from a seperate pipe from the main intake pipe and the nb8 version is built inturnal taking in just before the butterfly.
Tony
Postby Tony » Sun Jan 20, 2013 2:16 pm
Without a photo it's difficult to tell.
My guess (for what it's worth) is that it's probably a water hose connection for the hoses that run to the thermostat housing and to the oil cooler behind the filter.
'09 NC2
