EGR Pipe to New Headers
Posted: Sun Jan 13, 2013 8:39 am
by KarlMazda
Hello all, New here and looking for some advice!
I fitted some Empire Performance extractors onto my NB..
All went well except for the fitment from the EGR to the Manifold, they are both female counterparts?
I was just wondering if anyone had come across this problem and have a solution for it?
Heres a picture just to kind of explain what I'm dealing with:
Thanks for the help in advance, and looking forward to spending more time on here!
Re: EGR Pipe to New Headers
Posted: Sun Jan 13, 2013 12:33 pm
by Steampunk
Block them off, they are not vital.
Posted: Sun Jan 13, 2013 1:09 pm
by KarlMazda
I would block them off if I could, I've been struggling to find anything at all that will fit either of the pipes!
The whole situation is very, annoying.
Posted: Sun Jan 13, 2013 5:48 pm
by tbro
Enzed, Pirtek, Ryco, any hydraulic hose place will have blanking plugs or can supply joiner.
Posted: Sun Jan 13, 2013 6:03 pm
by Steampunk
Is the issue space or finding the correctly threaded blanking plug/bolt?
Is the EGR pipe flexible enough to give you more room?
can you get to the other end of the EGR pipe easy? (Sorry I am not all that well versed with NB BP engines, surely someone here with first hand experience will contribute). If so, then is that end easier to undo and blank off?
Can you move/bend the EGR pipe?
Posted: Sun Jan 13, 2013 6:48 pm
by Hjt
My pipe is welded closed @ the exhaust.
Posted: Sun Jan 13, 2013 7:34 pm
by KarlMazda
Not so much an issue space, just finding a correctly threaded bolt.
I'm sure with abit of heat I could get the EGR Pipe alignment more or less.
Heading to my exhaust shop tomorrow so I'll see what they have to say, worst comes to worst I'll get them to weld it shut.
Thanks for your helps everyone, I appreicate it
Posted: Sun Jan 13, 2013 9:24 pm
by deviant
The EGR pipe changed over the years so it looks like you have a manifold designed for another year.
If you follow it across the back of the engine you will very easily see where it joins the inlet side of the engine. It is only held on with a couple of 8 or 10mm bolts and is very easy to access.
Yes it can be removed and you can make up a blanking plate to block off where it went on the inlet side. You WILL get a check engine light on permanently though.
If you want to blank it all off you can buy the bits here:
http://www.bellengineering.net/advanced ... 88&x=0&y=0If you want to keep the EGR then you need to drill a hole in the manifold and weld this on:
http://www.bellengineering.net/product_ ... cts_id=413The EGR pipe can be bent fairl easily but it will crack easily where it joins the flange at the end that joins to the inlet side.
Posted: Mon Jan 14, 2013 5:34 am
by rascal
deviant wrote:You WILL get a check engine light on permanently though.
Not always true..
I have blocked off the EGR on my NB8A with a blanking plate on inlet side and I don't get any check engine lights on...
Posted: Mon Jan 14, 2013 12:54 pm
by hks_kansei
I thought it was only the US versions that got the check engine light. (ie: Aussie versions don't have any check engine light at all)
Posted: Mon Jan 14, 2013 3:13 pm
by deviant
Intredasting...I could only find information from the US when it came to deleting the EGR pipe so when I had a NitroDann exhaust system built I had him put an EGR fitting on it.
I thought we would have a warning light on an NB8B? Can't say as I look to closely at the dash lights when I start the car to be honest!
Posted: Mon Jan 14, 2013 3:28 pm
by Hjt
my check engine light isn't on, it has been 3 months now.
Posted: Mon Jan 14, 2013 3:59 pm
by hks_kansei
deviant wrote:I thought we would have a warning light on an NB8B? Can't say as I look to closely at the dash lights when I start the car to be honest!
NB8B could possibly have one, but I doubt it.
The whole "check engine" light concept seems to be very much a US thing anyway (talking in general, I can't think of any non-us cars with one)
Neither my Aussie or Japanese gauge clusters had a provision for a check engine light from memory (but that's NB8A)
Posted: Mon Jan 14, 2013 5:11 pm
by KarlMazda
No engine light as of yet.
Welded up the hole in the manifold and going to create a basic blanking plate for the EGR.
Sounds soo much nicer now without a hole in the top of my exhaust..
Posted: Mon Jan 14, 2013 8:06 pm
by Okibi
I kept the unused ERG valve plugged in and had no check engine light.
