Anyone know what it is/where it's from?
Dimensions are 55mm long, shaft is 12mm in diameter, head is 22mm in diameter with a 5mm hole though it.
Jeo wrote:When I removed the front undertray to replace the radiator in the LE (NA6), this fell out...
manga_blue wrote:Probably fell off an Alfa. Stops rear doors from falling off when opening drivers side window.
RedMX wrote:Do I win a prize if I get this right?
NitroDann wrote:RedMX wrote:Do I win a prize if I get this right?
You are right, but you would have to ask dave about the prize.
davekmoore wrote:NitroDann wrote:RedMX wrote:Do I win a prize if I get this right?
The prize is a pair of rear doors off a Sud Sprint.
Jeo wrote:Spot on. Thanks RedMX!
