Shown below, the outlet is situated between the exhaust and gearbox.
Thanks.
Travis
Correct.Muzdaman wrote:Pretty sure its a drain from the AC Box under the dash.
Matt wrote:Yep, perfectly normal to drip water. It's the drain tube from the A/C evaporator, which during normal use and depending on humidity, can build up quite a bit of condensation. The drain gives it somewhere to go. If they block, and they do occasionally, you'll find yourself with a wet passenger footwell.
