Will this make it quieter?
CheyneX5
Postby CheyneX5 » Mon Dec 03, 2012 7:14 pm
Hey Guys,
I installed a new exhaust system today, it consists of a set of 4-1 MazdaSpeed Extractors, Maruha 100 Cell High Flow Cat and a Car Make Corns Cat Back System.
Now I am already aware that this is a recipe for LOUD.
After installing it and a short drive... It sounds great. The only gripe I have is that it drones quite a bit between 3-4k rpm. Everywhere else is ok.
My guess at fixing this with out cutting pipe is to reinstall my 300 cell high flow cat and remove the 100 cell. I know this wont change it dramatically, but will it at least take out some drone?
Cheers.
90' NA6 - Classic Red
Re: Will this make it quieter?
Postby NitroDann » Mon Dec 03, 2012 7:17 pm
Nope, go to a really high end exhaust shop and have the TIG in a nice stainless hotdog.
It will look like it belongs.
CheyneX5
Postby CheyneX5 » Mon Dec 03, 2012 8:08 pm
Thanks Dann,
As mentioned above, I'd rather not modify it as it took a bit to find one in such good nick.
A mate of mine, Johnny has this same cat back fitted to his car with some MaximWorks 4-2-1 headers and a 300 Cell Cat and its not as droney as mine... That's why I asked If that cat would make a difference, as it has more resistance.
Postby NitroDann » Mon Dec 03, 2012 8:12 pm
Adding restriction to your performance exhaust?
honestly what is the point?
CheyneX5
Postby CheyneX5 » Mon Dec 03, 2012 8:18 pm
Haha, I know. Seems pointless, but it's not going to be anything major...
I'm happy to do it if it will make it a little more tame. I don't mind if the difference is not massive, but if it will make the drone a little less "droney", then I'm sold on the idea.
Postby manga_blue » Mon Dec 03, 2012 11:34 pm
Cheyne, you could try waiting a couple of weeks before you make any changes. Some new exhausts settle down, getting quieter and deeper during the first few drives.
CheyneX5
Postby CheyneX5 » Mon Dec 03, 2012 11:34 pm
Anyone else have anything to add to this?
CheyneX5
Postby CheyneX5 » Mon Dec 03, 2012 11:35 pm
It's a used exhaust Manga, imported from Japan...
Postby NitroDann » Mon Dec 03, 2012 11:36 pm
Consider putting a muffler where the cat goes perhaps?
Postby manga_blue » Mon Dec 03, 2012 11:51 pm
CheyneX5 wrote:It's a used exhaust Manga, imported from Japan...
OK, clearly I got confused when you used the word "new" in the first post. :D
x2 for the hot dog after the cat idea then.
timk
Postby timk » Tue Dec 04, 2012 12:12 am
Changing the cat to a higher flow one on my SE system made a big difference in volume, so I would say yes to the reverse.
project.r.racing
Postby project.r.racing » Tue Dec 04, 2012 8:54 am
Yeah it'll change, but it will be a minimal change. You dont hear the droning gone, but it will be less audible. Personal choice would be not to touch it. But it is your car.
bensale
Postby bensale » Tue Dec 04, 2012 10:34 am
Yep - change the cat to the 300 CEL one and most of it will go away. I was surprised how much difference a 100 CEL makes and TBH on a 1.6 it shouldn't really effect performance much at all. It's free to swap it back ;)
www.othersideproductions.com
pcmx5
Postby pcmx5 » Tue Dec 04, 2012 11:13 am
Steel cats of that spec are noisy in my experience,much more than ceramic.I agree with the hotdog , say 15 inch but use a perforated one ,have had much better results with sound and quietening using perforated, don't ask why as i don't know.
Getting a good sound and avoiding that drone is the real cahallenge with MX catbacks
Good luck,
Peter
Postby NitroDann » Tue Dec 04, 2012 11:14 am
If its affecting sound a lot through restriction alone it must be affecting performance.
