Running a tad rich ? OEM NA6
Basho
Postby Basho » Mon Nov 12, 2012 9:20 pm
I just changed my plugs and noticed that they were slightly sooty so as I blow no smoke , use nil oil (or coolant) but have a slighly variable fuekl consumption I deduce thatI an running a tad rich. :shock:
Why would this be so ?
Any tips gratefully received :beer:
koop21
Re: Running a tad rich ? OEM NA6
Postby koop21 » Mon Nov 12, 2012 9:25 pm
i'm not sure why all of a sudden your car is running more rich then normal; but something you should know is na6 normally run rich to begin with because it uses batch injection.
PaulF
Postby PaulF » Mon Nov 12, 2012 9:54 pm
Do you get a bit of black sooty stuff on the rear bumper above your muffler tip?
Postby KevGoat » Mon Nov 12, 2012 10:20 pm
My 1990 NA6 gets a reasonable amount of black "soot" on the chrome exhaust extension (though not on my bumper) yet mine also doesn't blow smoke or use any more oil than I'd expect. I thought I had a problem at first, but have since been thinking it must be normal as doesn't appear to affect anything.
Postby hks_kansei » Tue Nov 13, 2012 10:21 am
It's normal, they all do it.
Postby 93_Clubman » Tue Nov 13, 2012 10:28 am
Yeah, it's common - my old NA6 was the same.
Standard 1991 NA6 fitted with wideband O2 sensor - results here:
viewtopic.php?f=29&t=39059&p=506711
Basho
Postby Basho » Tue Nov 13, 2012 11:49 am
Thanks for the replies all , nothing on the bumper and normal as clean as an exhaust pipe is , just got an overun of paranoia :lol:
ja9
Postby ja9 » Fri Nov 16, 2012 4:09 pm
Basho wrote:Thanks for the replies all , nothing on the bumper and normal as clean as an exhaust pipe is , just got an overun of paranoia :lol:
Maybe paranoia but check the O2 sensor just to be sure everything is ok.
UNDERSTEER is when you hit the wall with the front of the car. OVERSTEER is when you hit the wall with the rear of the car.
Basho
Postby Basho » Sat Nov 17, 2012 8:49 pm
Thanks renewed 5000ks ago with a Denso replacement but will check anyway :beer:
