NC Drive by wire signal multipyer module
RedMX
Postby RedMX » Sun Nov 04, 2012 11:02 pm
I found this. I don't know if it to any use to anybody or if anybody uses one, I know that drive by wire systems can get a little slack when trying to drive spirited can be a little tricky on the downshift when trying to heel & toe etc.
http://www.ebay.com.au/itm/Sprint-Booster-II-selectable-for-MAZDA-MX5-all-engines-2006-/260942990675?pt=AU_Car_Parts_Accessories&hash=item3cc16a0d53
As this a little useless to me as I drive a Na6 :roll: But feel free to discuss. :NC:
emex
Re: NC Drive by wire signal multipyer module
Postby emex » Sun Nov 04, 2012 11:07 pm
Could be interesting....someone else can guinnea pig it before I decide I have to have it LOL
2006 NC Galaxy / Black manual soft top. Ipod, K&N, leathery bits & piano black with smoked repeaters...The love affair has moved up a notch.
JBT
Postby JBT » Mon Nov 05, 2012 10:26 am
RedMX wrote:....I know that drive by wire systems can get a little slack when trying to drive spirited can be a little tricky on the downshift when trying to heel & toe etc.
Not a problem in the NC.
Sailor
Postby Sailor » Mon Nov 05, 2012 10:26 am
At that price you're well on your way to getting a flash tune with throttle response adjusted, rev limit raised if wanted and more power.
Seems like the decision would be easy.
Rob
Postby hks_kansei » Mon Nov 05, 2012 12:02 pm
I'm pretty sure these work by simply amplifying the signal.
Where on the stock system moving the pedal down say 10% might correspond to the car opening the throttle to 10%, with the booster thing the same 10% pedal movement may now tell the throttle to open by 15%
It's not speeding up the response time, it's just making the same pedal travel open the throttle more/faster.
http://www.ozhonda.com/forum/showthread ... d-Euro-CL9
project.r.racing
Postby project.r.racing » Mon Nov 05, 2012 3:16 pm
hks_kansei wrote:I'm pretty sure these work by simply amplifying the signal.
Cons:
1. Cheap looking and doesn't seem like good value
2. Limited documentation (esp installation)
3. Doesn't add HP/torque at all
4. Reduced pedal resolution - 75%+ is full throttle
5. Might increase fuel consumption slightly
I lol'ed at hos list of cons.
1. It's a matte black plastic box. How much better than than cheap looking do you need? It's hidden under the dash anyway.
2. Fair enough, but not really a con of the product itself.
3. Product doesn't claim to do those things.
4. If he knew how to drive, this would be a pro, not a con. Less pedal travel the better.
5. Might be his foot doing the damage while gunning it while testing, not the product.
