leaking rear main seal / oil on clutch?
Re: leaking rear main seal / oil on clutch?
if you are doing the job its your labour time if you are paying for it then you probably replace the clutch as a unit. Its not a 5 minute job.
If the leak is minimal, perhaps just live with it.
- Vehicle: Non MX-5
it'll be rare to find any oil on the clutch. as the leak is on one side of the flywheel, and the clutch is on the other side.
