I have a MS2 coming, i am going to delete the 1.6 throttle body and Flyin Miata spacer as i now have a 1.8 TB with a variable TPS.
I know the NA8 Intake pipe will not work with a 1.6 thermostat housing and coolant hose.
I have a coolant reroute to go on the car and will be blocking off the Front thermostat housing with a plate.
My question is, does anyone know if the NA8 OEM INTAKE PIPE will then fit?
It will be ohh so easy for me to just get hold of that pipe if it does.
I will just tap it for the IAT sensor and be ready to go while looking quite neat.
If it will not work, i assume then i would need to go to the effort of changing the thermostat housing to a NA8.
Would like to avoid this for now.
Thanks in advance everyone!!
