BP - Duratec bellhousing pattern
wozzah1975
Postby wozzah1975 » Thu Oct 18, 2012 5:38 pm
Hoping someone can answer this.
Is the bolt pattern on the Duratec and B series (BP) bellhousing-block pattern the same?
Eg: does a duratec bolt to a BP gearbox?
Woz
sailaholic
Re: BP - Duratec bellhousing pattern
Postby sailaholic » Thu Oct 18, 2012 6:51 pm
Is the duratec the same engine as the mazda mzr?
mrpham
Postby mrpham » Thu Oct 18, 2012 6:58 pm
Don't know if it's the same bolt pattern, but I know that the starter motor is on the opposite side.
Current Forum Specials!
wozzah1975
Postby wozzah1975 » Thu Oct 18, 2012 9:16 pm
mrpham wrote:Don't know if it's the same bolt pattern, but I know that the starter motor is on the opposite side.
Any of the hang on's don't matter, as long as it bolts up :)
Woz
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Fri Oct 19, 2012 10:57 am
if you figure out how to do a duratech swap i may just pay you to do it to mine!!!!!!
mx5racing
Postby mx5racing » Fri Oct 19, 2012 11:14 am
No they dont fit.
wozzah1975
Postby wozzah1975 » Fri Oct 19, 2012 1:03 pm
mx5racing wrote:No they dont fit.
Thank you,
Woz
