walpro fuel pump
Posted: Sun Oct 14, 2012 9:41 pm
by funmx5
ANY ONE INSTALLED A WALPRO PUMP IN A NA ,FLANGE USED ON INLET SIDE ?OR CUT OFF
Re: walpro fuel pump
Posted: Mon Oct 15, 2012 12:18 pm
by 93_Clubman
funmx5 wrote:ANY ONE INSTALLED A WALPRO PUMP IN A NA
Yes, a Walbro GSS340 into an NA8.
funmx5 wrote:FLANGE USED ON INLET SIDE OR CUT OFF
? - http://www.autoperformanceengineering.c ... mazda_apps
Posted: Mon Oct 15, 2012 12:33 pm
by funmx5
thanks 93 clubman/thought that would be case !!
Posted: Mon Oct 15, 2012 12:52 pm
by 93_Clubman
GSS242 at 190 LPH should also be fine, just that GSS340 at 255 LPH was what I already had in the garage.
Posted: Fri Nov 09, 2012 10:18 pm
by funmx5
any one had trouble using 255 lph pump on stock engine?
Posted: Sat Nov 10, 2012 1:25 pm
by 93_Clubman
No problem using it on lightly modified NA8, but did read on Miata.net early last year when I was swapping fuel pumps that some thought they might over time. Quick look on the big forum just now found this: http://forum.miata.net/vb/archive/index ... 94497.html
Posted: Sat Nov 10, 2012 2:15 pm
by funmx5
thanks for that clubman ,i have install the 255lph it runs ok for a while then it starts to cut out ,then runs ok on light throttle ,i first thought it was coil packs but checked them with a ohms metre they are all in resistance spec
Posted: Sat Nov 10, 2012 3:08 pm
by 93_Clubman
Don't think it's the so called 'black wire' issue but worth checking continuity at outer top of tank in case it's variable: viewtopic.php?f=55&t=46425
Posted: Sun Nov 11, 2012 10:09 am
by Steampunk
I'm not making fun, but do you mean Walbro?
There are knock offs rife on the internets all of them advertise a flow rate far exceeding their capabilities. Just wondering if there is actually a Walpro branded one that you've been eyeing, and if so, stay away. Genuine Walbro's are cheap enough as it is, compared to Bosch, so make sure you do your homework and buy from a reputable shop.
