walpro fuel pump
- funmx5
walpro fuel pump
ANY ONE INSTALLED A WALPRO PUMP IN A NA ,FLANGE USED ON INLET SIDE ?OR CUT OFF
red na6
cx7
cx7
Re: walpro fuel pump
funmx5 wrote:ANY ONE INSTALLED A WALPRO PUMP IN A NA
Yes, a Walbro GSS340 into an NA8.
funmx5 wrote:FLANGE USED ON INLET SIDE OR CUT OFF
? - http://www.autoperformanceengineering.c ... mazda_apps
- funmx5
GSS242 at 190 LPH should also be fine, just that GSS340 at 255 LPH was what I already had in the garage.
- funmx5
No problem using it on lightly modified NA8, but did read on Miata.net early last year when I was swapping fuel pumps that some thought they might over time. Quick look on the big forum just now found this: http://forum.miata.net/vb/archive/index ... 94497.html
- funmx5
thanks for that clubman ,i have install the 255lph it runs ok for a while then it starts to cut out ,then runs ok on light throttle ,i first thought it was coil packs but checked them with a ohms metre they are all in resistance spec
red na6
cx7
cx7
Don't think it's the so called 'black wire' issue but worth checking continuity at outer top of tank in case it's variable: viewtopic.php?f=55&t=46425
- Steampunk
I'm not making fun, but do you mean Walbro?
There are knock offs rife on the internets all of them advertise a flow rate far exceeding their capabilities. Just wondering if there is actually a Walpro branded one that you've been eyeing, and if so, stay away. Genuine Walbro's are cheap enough as it is, compared to Bosch, so make sure you do your homework and buy from a reputable shop.
Users browsing this forum: No registered users and 23 guests
