Power steering delete idler pulley?!
Tedman
Postby Tedman » Sat Oct 13, 2012 2:11 am
Hi all, as some may know, I own a 1990 NA6 with about 210klms.
I'm getting a horrible noise coming from the idler bearing that goes where the power steering pump should be.
Are these readily available anywhere? Need the car daily, had a look and it seems pretty straightforward enough to do.
Can any replacment bearing just be pushed in or do I need a complete replacment part?
Thanks for the info in advance :D
project.r.racing
Re: Power steering delete idler pulley?!
Postby project.r.racing » Sat Oct 13, 2012 10:23 am
auto shop? ebay? wreckers?
Tedman
Postby Tedman » Sat Oct 13, 2012 10:32 am
Can't find a simgle mention of it on eBay, called all Mazda wreckers in Perth but none have an mx5 in for wreaking.
Just wondering if I can press a new bearing into the "belt retaining groove" or is it all one piece that needs to be ordered as a whole.
I use the car everyday so haven't even had it off for a look...
Thanks...
sailaholic
Postby sailaholic » Sat Oct 13, 2012 10:35 am
Tried mx5plus?
spikes
Postby spikes » Sat Oct 13, 2012 10:59 am
Replace the bearing perhaps, take the pulley into a bearing shop and match up an appropriate sized bearing?
myredmx5
Postby myredmx5 » Sat Oct 13, 2012 11:49 am
If the power steering has been removed why not just remove the idler bearing and replace the belt.
Tedman
Postby Tedman » Sat Oct 13, 2012 5:52 pm
Done it this morning, bearing is not meant to be changed it's own, but with a press you can manage it.
I'll get the bearing number and put it up here for furthern reference :D
Tedman
Postby Tedman » Wed Oct 17, 2012 1:01 am
Bearing number is 6301DUX (NSK bearing)
Hopefully this will help someone in future :D
