Cometic head gasket
sticky nicky
Cometic head gasket
Postby sticky nicky » Fri Aug 31, 2012 8:51 pm
Does anyone know who can supply cometic head gaskets in Australia?
Thanks
project.r.racing
Re: Cometic head gasket
Postby project.r.racing » Sat Sep 01, 2012 8:52 am
any auto parts shop.
BOYRCR
Postby BOYRCR » Sat Sep 01, 2012 6:35 pm
Isn't the head gasket that comes in your standard full engine gasket kit cometic?
If it aint on the rev limiter then you shouldn't be behind the wheel!
sticky nicky
Postby sticky nicky » Sat Sep 01, 2012 6:52 pm
Ive been looking on the net and none of the full gasket sets Ive seen are Cometic. I can get the Cometic head gasket from the UK or USA but looking at about $150 for it posted. The US one is $50 postage which is crazy for such a small light thing.
Im in Perth, Ill have to do some more searching as they dont seem ready available in the autoshops over here.
Pamex
Postby Pamex » Sat Sep 01, 2012 6:59 pm
www.horsepowerworld.com.au
Looks like they're an Australian supplier (in Vic).
In a thread, someone mentioned Chris Mills Performance over in Perth.
Or looks like Road and Track in QLD supply Cometic gaskets.
Any reason why you're after Cometic in particular? Just interested.
sticky nicky
Postby sticky nicky » Sat Sep 01, 2012 9:11 pm
Thanks Pamex, I am currently having a head job done on my mx which has a turbo. Its only running 170rwhp but I do a fair bit of track work. My mechanic who Ive used for 20 odd years has told me these gaskets are good quality, he builds westfields. I just want to make sure I do the job properly and dont want to go cheap. Can you recommend any other make of good quality head gasket, appreciate any info :)
Cheers.
project.r.racing
Postby project.r.racing » Sun Sep 02, 2012 8:38 am
sticky nicky wrote:Thanks Pamex, I am currently having a head job done on my mx which has a turbo. Its only running 170rwhp but I do a fair bit of track work. My mechanic who Ive used for 20 odd years has told me these gaskets are good quality, he builds westfields. I just want to make sure I do the job properly and dont want to go cheap. Can you recommend any other make of good quality head gasket, appreciate any info :)
Cheers.
shouldn't your mechanic be able to source and supply you one then?
sailaholic
Postby sailaholic » Sun Sep 02, 2012 9:38 am
Genuine Mazda has a good reputation from who I talked to.
Postby NitroDann » Sun Sep 02, 2012 10:47 am
All the 300+rwhp guys run OEM.
