NB Shifter into NA Gearbox? Lil Help please.
Dweezle
Postby Dweezle » Wed Aug 01, 2012 11:54 am
My Project CRAPBOX came with a shortshifter that is broken.
I have secured a NB gear Shifter from ZOSSY1 (thanks mate).
It has 2 slots, one front and back and no plastic piece in either slot.
The NA uses a slot just at the front and usually with a plastic piece.
I have looked on various pages and get lots of conflicting reports.
Can anyone please confirm for me that the NB Shifter will or will not work in a NA box?
This COMPATIBILITY GUIDE suggests that the NA will not work in NB but the NB will work in NA.
http://www.miata.net/garage/compatibility.html
5-speeds:
a) 1989-2005 lengths and tip diameters are the same (15mm tips)
b) 1989-1997 has wide slot for crescent-shaped plastic bushing for dowel pin (on one side only)
c) 1999-2005 has narrow metal slots without bushings (180* apart on both sides)
Does this mean i can use the NB shifter and do not need to worry about the plastic bushing?
I just do not want to put my new rubber boots onto the lever if it will be not so good.
I do not think they will come back off without damage.
Sorry to be a pain.
Thanks in advance!
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
zossy1
Re: NB Shifter into NA Gearbox? Lil Help please.
Postby zossy1 » Wed Aug 01, 2012 12:38 pm
Mark, forget the new turret boot for the moment - pop the shifter in and drive it around the block, see how it goes ;)
Sean
Postby Sean » Fri Aug 03, 2012 3:25 pm
Yep.
Put it in - It will work.
