Hw much for replacing timing belt?
edge
Postby edge » Fri Jul 13, 2012 2:06 am
Hi Guys,
Im just wondering how much should I expect to pay for when replacing all the belts? I've been told that it should be a fairly easy job as it doesn't require to take the engine out.
Just wana do some research so I can have a rough figure in my head of how much should I prepare for, or can anyone share their experience regarding the cost of changing their timing belt?
I'm also thinking of doing advance timing while i get the belts replaced, any suggestions?
by the way my car is a 1992 NA MX5 :D :beer:
Thanks
Re: Hw much for replacing timing belt?
Postby NitroDann » Fri Jul 13, 2012 2:26 am
Anywhere from 80 bucks doing it yourself, to a few hundred for a professional job to a few thousand for a ripoff job.
zossy1
Postby zossy1 » Fri Jul 13, 2012 11:51 pm
There are several threads on this topic. I have posted on this topic a number of times.
Basho
Postby Basho » Sat Jul 14, 2012 9:02 am
Heres mine from Mazda, if you're going to buy the parts separately it'll give you an idea of whats wanted.
http://imageshack.us/photo/my-images/851/gcmp2.pdf/
http://imageshack.us/photo/my-images/35/gcmp1.pdf/
david_syd_au
Postby david_syd_au » Sat Jul 14, 2012 11:08 am
When doing a timing belt, it is best to also do water pump plus crank and cam seals
A kit with all the parts to do this is about $300
Labour is probably going to be around $300, maybe $400
As others have said, there are a number of discussion threads on this topic. Suggest you do a search for more details.
edge
Postby edge » Sun Jul 15, 2012 5:53 pm
thanks for the input guys :D
OurCognitiveSurplus
Postby OurCognitiveSurplus » Fri Jul 20, 2012 4:20 pm
I just paid $1500 to get the pump and belt done. Depends if there are other issues going on...
NB8A - Twilight Blue
