Differential ratios
- timk
Re: Differential ratios
You can get a direct swap 4.7 ish out of a Kia Sportage apparently. I don't know the details but I do know a few people are running them on here with 5 speed boxes.
- Guran
- Vehicle: ND - 1.5
Mazda Motorsports apparently do ring & pinion sets in 4.44, 4.875 and 5.125. Not sure where you'd get them though. This info comes from Norm Garrett's book.
Yes you can get a 5.1 but it's aftermarket from Mazda or Kia
Made from the same 7' ring and piñon
Just remember with your electric motor it has instant toque, so hill starts will not be a issue.
You could always use a reduction gearbox inline, check SEW
But top end will be more of a problem with your car I would think
Are you running a dc or ac
Also depends on your. Controller as well
Worth also noting that the replacement crown and pinion sets mentioned are for the 1.8 diff (7in crown)
NOT the 1.6 diff (6in crown)
Guran wrote:Mazda Motorsports apparently do ring & pinion sets in 4.44, 4.875 and 5.125. Not sure where you'd get them though. This info comes from Norm Garrett's book.
4.875 is out of a front diff out of a Kia sportage about $200 for the whole diff if you can get one.
Toppertree 4.77 is from the Kia front diff. 4.875 is an aftermarket diff. Mazdaspeed makes 4.875 & 5.125 diff for the 1.8, you can get them through our sponsor MiataRoadster or Yahoo Japan. I'm currently running 4.875 on my NA8, bang for buck for torque increase.. Not so good on highway though lol
MiGoreng wrote:Toppertree 4.77 is from the Kia front diff. 4.875 is an aftermarket diff. Mazdaspeed makes 4.875 & 5.125 diff for the 1.8, you can get them through our sponsor MiataRoadster or Yahoo Japan. I'm currently running 4.875 on my NA8, bang for buck for torque increase.. Not so good on highway though lol
Right you are.
Yep I've pulled one out of the kia, works well. Nothing like pulling 4 grand in 5th at 100km/ph.
When I was looking around, I'm pretty sure you can get the 5.1 ratio from KIA may be cheaper than the MS unit. A few of the 4x4 guys are using it.
http://www.solomiata.com/Drivetrain.html
- Vehicle: ND - 2
I will have a couple of 5.125:1's in about 4 weeks.
Have another on order coming from Japan in the next few days will be here in approx. 1 week
- NitroDann
Im no electric expert but if the same principles work then the only important thing is HP output.
Unfortunately with no clutch you need to make thousands of NM of torque at 1rpm to make any useable amount of horsepower to take off from a stationary start.
- NitroDann
Also are you saying that 136k/h is the speed the car will reach at 6000rpm? You should find out how many HP is required to get an NA to do 110kph, and find out if your electric motor makes that HP at the rpm it will be spinning to do 110.
The only practical way I can think of on top of my head is to get a car with a throttle position sensor, do 110 on the flat, no wind, roof up. Check throttle percentage, and then get on the dyno, same gear, same RPM same throttle percentage and the dyno will give a HP readout. Within 10%.
- NitroDann
So for example even if you can get 10rpm out of the motor in driveline twist upon a stationary takeoff it still takes 21,338NM of torque to make 30hp and give an even moderately zippy takeoff.
Perhaps a torque convertor with lockup would fix these issues?
- Vehicle: ND - 2
No sorry I dont have a website I just play with Mazda diffs on the weekends and have a full time day job. I keep some ratios in stock because I get asked for them a lot.
Dan have you ever seen this?
http://www.youtube.com/watch?v=UAYrsEOxqYc
Duane
Duane
- Beelzeboss
- Vehicle: Non MX-5
NitroDann wrote:Im no electric expert but if the same principles work then the only important thing is HP output.
NitroDann wrote:So for example even if you can get 10rpm out of the motor in driveline twist upon a stationary takeoff it still takes 21,338NM of torque to make 30hp and give an even moderately zippy takeoff.
That's not how it works, acceleration is based on torque at the wheels, not HP.
Think about it, according to your theory if you loaded up the drivetrain with an electric motor and then let off the brake, since it's doing 0rpm then it would need infinite torque to move which is clearly not the case. If it's producing a lot of torque at 0rpm in a light chassis then it's going to take off like a stabbed rat, even though it's not making any HP when stationary.
It's just physics. Apply torque, you get angular acceleration of the wheels.
HP is important if you take into account different gear ratio's which change the torque at the wheels. Higher rpm in a lower gear provides more torque at the wheels and therefore faster acceleration. However for an electric motor which only has one gear it's largely irrelevant.
- NitroDann
yeah hence more acceleration in lower gears.
that was a pretty late night post haha.
What sort of rw tq does an na6 make in first on a hard launch?
Users browsing this forum: No registered users and 19 guests
