Gear lever is perfect. I've merely upgraded to a short shifter. Lower rubber boot is fine. Replacement upper boot is needed (they're $45).
Engine mounts also perfect. The bushes will probably need replacing though. I'm no expert but I understand the mounts are good for some non-SE cars and you can also buy stiffer rubber bushes. Again, no known faults with these mounts. I've merely upgraded to bigger ones with much stiffer bushes.
Pics will follow if needed.
FS: SE 6 speed gear lever and engine mounts
- davekmoore
- Steampunk
