Page 1 of 4
Taptaptaptaptaptaptap Noise?
Posted: Thu Jun 07, 2012 3:43 pm
by bear2230
Hi All,
I have developed a little tap tap tap noise. Sounds like its coming from the head but not sure.
It is at the mechanics now but can anyone give me a quick diagnosis???
Richard.
I should add we just turned up the boost to 15PSI and 173rwkw. (please dont say rods, please)
We have now turned back down to 12PSI and 156rwkw.
Re: Taptaptaptaptaptaptap Noise?
Posted: Thu Jun 07, 2012 3:50 pm
by Willstar
It sounds like it might be going "pingpingpingpingping" rather than "taptaptaptaptaptaptap".
Posted: Thu Jun 07, 2012 3:53 pm
by bear2230
Posted: Thu Jun 07, 2012 4:03 pm
by Willstar
Well that's me out of ideas then!
Posted: Thu Jun 07, 2012 4:14 pm
by Uncle Arthur
bear2230 wrote:Hi All,
Richard.
taptaptaptaptap like lifters on startup?
Posted: Thu Jun 07, 2012 4:21 pm
by bear2230
taptaptaptaptap like lifters on startup?[/quote]
On start up but doesn’t go away and increases when revved. Not super noisy but you can hear from outside the car clearly
Posted: Thu Jun 07, 2012 4:43 pm
by Uncle Arthur
bear2230 wrote:taptaptaptaptap like lifters on startup?
On start up but doesn’t go away and increases when revved. Not super noisy but you can hear from outside the car clearly[/quote]
So it could be that the lifters have collapsed, or perhaps your oil isn't coping?
Tried changing it?
Posted: Thu Jun 07, 2012 5:01 pm
by Uncle Arthur
ozi_milhouse wrote:
it could be anything, but does it sound like piston kissing head? is it really loud?
I don't believe this is physically possible in the MX5 engine is it?
Posted: Thu Jun 07, 2012 5:05 pm
by bruce
Yup, non-interference engine.
But, it does not sound good at all (ie. expensive).
Posted: Thu Jun 07, 2012 5:07 pm
by bear2230
Uncle Arthur wrote:bear2230 wrote:taptaptaptaptap like lifters on startup?
Tried changing it?[/quote]
I'm thinking lifters have sh*t themselves. I think. Oil was changed 1 month ago at Mania when they did 25000km service.
ozi_milhouse wrote:Did you give it a good rev at higher boost?
Did you engine brake on down shift?
or did you amend tune? play with idle control valve?
could be anything.
High pressure fuel pump was installed and boost increased while on the dyno only. It was revved at higher boost but not over revved on down shift
Doesn’t sound like piston kissing head but haven’t heard many pistons kissing heads before. But not really loud.
play with idle control valve? I’m not sure.
Posted: Thu Jun 07, 2012 5:09 pm
by project.r.racing
lifters or injectors
Posted: Thu Jun 07, 2012 5:15 pm
by bear2230
bruce wrote:Yup, non-interference engine.
Mother F@#ker
Posted: Thu Jun 07, 2012 5:25 pm
by bear2230
project.r.racing wrote:lifters or injectors
Much better
Posted: Thu Jun 07, 2012 5:50 pm
by Russellb
[quote="Uncle Arthur
I don't believe this is physically possible in the MX5 engine is it?[/quote]
IF it has spun a bigend bearing then the Pistons can hit the head
But with out hearing the engine Its hard to tell whats wrong
The last time I ran the race car on 14psi with STD rods it Broke 1 and bent 3.
1 was so bend that the crank balance weights where hitting the bottom of the piston
and making a horible noise.
not saying that it is the problem as there are over 400 parts inside the engine and anyone of them
could cause a noise is it fails
Posted: Thu Jun 07, 2012 6:37 pm
by bear2230
Russellb wrote:[quote="Uncle Arthur
could cause a noise is it fails[/quote]
Holly F$%k Russell dont tell me that.
