Taptaptaptaptaptaptap Noise?
- bear2230
Hi All,
I have developed a little tap tap tap noise. Sounds like its coming from the head but not sure.
It is at the mechanics now but can anyone give me a quick diagnosis???
Richard.
I should add we just turned up the boost to 15PSI and 173rwkw. (please dont say rods, please)
We have now turned back down to 12PSI and 156rwkw.
Richard.
- Willstar
Re: Taptaptaptaptaptaptap Noise?
It sounds like it might be going "pingpingpingpingping" rather than "taptaptaptaptaptaptap".
- bear2230
Definitely taptaptap, Tune is good. Tap is bad.
- Willstar
Well that's me out of ideas then!
- Uncle Arthur
- Dodgy Award Benefactor
- Location: Doesn't matter where I'm from-it's that your daughter is with me that's the biggest concern :D
bear2230 wrote:Hi All,
Richard.
taptaptaptaptap like lifters on startup?
- bear2230
taptaptaptaptap like lifters on startup?[/quote]
On start up but doesn’t go away and increases when revved. Not super noisy but you can hear from outside the car clearly
- Uncle Arthur
bear2230 wrote:taptaptaptaptap like lifters on startup?
On start up but doesn’t go away and increases when revved. Not super noisy but you can hear from outside the car clearly[/quote]
So it could be that the lifters have collapsed, or perhaps your oil isn't coping?
Tried changing it?
Did you give it a good rev at higher boost?
Did you engine brake on down shift?
it could be anything, but does it sound like piston kissing head? is it really loud?
or did you amend tune? play with idle control valve?
could be anything.
could be anything.
- Uncle Arthur
I don't believe this is physically possible in the MX5 engine is it?
- bruce
- Vehicle: NA8 - Turbo
Yup, non-interference engine.
But, it does not sound good at all (ie. expensive).
- bear2230
Uncle Arthur wrote:bear2230 wrote:taptaptaptaptap like lifters on startup?
Tried changing it?[/quote]
I'm thinking lifters have sh*t themselves. I think. Oil was changed 1 month ago at Mania when they did 25000km service.
ozi_milhouse wrote:Did you give it a good rev at higher boost?
could be anything.
High pressure fuel pump was installed and boost increased while on the dyno only. It was revved at higher boost but not over revved on down shift
Doesn’t sound like piston kissing head but haven’t heard many pistons kissing heads before. But not really loud.
play with idle control valve? I’m not sure.
- Vehicle: Non MX-5
lifters or injectors
- bear2230
bruce wrote:Yup, non-interference engine.
Mother F@#ker
- bear2230
project.r.racing wrote:lifters or injectors
Much better
Yeah sorry, should have prefaced that if your engine has been cracked open before. Have heard of a couple hi comp b6 motors stretch rods and kiss the head. not pretty.
If you played with the Idle control Valve duty cycle settings (after market comp like a mega squirt) and get them wrong, it will tap like a mother f&*K
Users browsing this forum: No registered users and 74 guests
