Hi. My NC has a real "rotten egg" odour after driving. When I pull into the garage, the sulphur smell is quite strong. Any ideas on what may be causing this? Faulty catalytic convertor? I doubt it is bad fuel, as I have continued to buy fuel from the same place and it is not a problem in our other cars.
Thanks in advance!
Re: Rotten egg smell
Posted: Wed May 30, 2012 6:51 pm
by project.r.racing
i think you almost answered your own question.
Posted: Wed May 30, 2012 6:53 pm
by NitroDann
Batteries that are overcharging also do this.
Caused by a faulty alternator regulator.
Posted: Wed May 30, 2012 7:04 pm
by Noddycar
Thanks for the replies.... It is under warranty, so I will take it in to get looked at. Wanted to make sure it was not a common issue before I do anything.
Posted: Wed May 30, 2012 7:10 pm
by marty085
Using e10?
Posted: Wed May 30, 2012 7:14 pm
by Jace
who farted?
Posted: Wed May 30, 2012 7:21 pm
by Noddycar
Using BP Ultimate.....
Posted: Thu Apr 04, 2013 12:57 am
by as_1
did you manage to get the smell away? i use bp ultimate too in mine and i've had that smell as well, nearly all the time
wondering if i should get it checked out also
Posted: Thu Apr 04, 2013 2:36 am
by Steampunk
Gearbox/diff oil can be rather pungent.
Posted: Thu Apr 04, 2013 8:53 am
by JBT
Mine doesn't do it - not that I've detected anyway. I use mostly Caltex Vortex 95 and the car has done 72,000km. I've experienced this odour following certain cars (mostly Toyotas) but never an NC.
Posted: Thu Apr 04, 2013 10:21 am
by manga_blue
Whenever I smell rotten eggs when I'm driving I look for the nearest new Commodore. There's almost always one in front. It's a special feature of the catalytic convertor that Holden use that they can absolutely stink when new. It goes away as the cat wears out and stops working.
It's usually nothing to do with the fuel. You don't need sulphur to produce sulphur-like smells. Some hydrocarbons like methyl mercatan smell more like sulphur than sulphur does.
