NB Starter Motor into NA
- CheyneX5
Hi Guys,
As above, will a NB starter motor go into a NA and is there any benefit?
Cheers.
Cheers.
90' NA6 - Classic Red
- geofiz
Re: NB Starter Motor into NA
Yes it will, quite bit lighter.
NB8A - mostly stock for now
- CheyneX5
Thanks for that, is it a direct swap or does it require some modification to fit?
- Steampunk
I've no idea but Send Richard at MX-5 Plus an email, but best try calling him on Saturday, as he's experimented with all different combos of starters/GB/flywheels and knows what works with what.
- CheyneX5
Cheers for that, i'll contact him and get back to this thread with any info i discover.
why bother- most of us just repair or buy the right product. What does an NB starter motor do that an NA doesn't?
- NitroDann
Might be available for very cheap or free, and it slighter, which wont affect 99.9% of us here but for example would be useful for me.
- lee
NitroDann wrote:Might be available for very cheap or free, and it slighter, which wont affect 99.9% of us here but for example would be useful for me.
99.9% of forum members don't care about 0.01% of the weight.
Occupy the starter motor!
'91 Roadster
- geofiz
It is actually quite a lot lighter, much easier to get hold off, easier to replace, more volumetrically efficient and more aesthetically pleasing.
I wouldn't go out of my to change it, but if it needs replacing then why not.
- CheyneX5
I got a reply from MX5 Plus. 2 out of 3 bolts line up. It could work i guess but there would be some modification involved. This is for NA8. Not sure about NA6.
- -alex
Needs late model NA8 or NB8A gearbox to be fitted without modifying.
- Boyracer
- MX-5 Encyclopedia
Fits no problem you just use 2 bolts.... No mods required. Much smaller and lighter and more efficient design.
- CheyneX5
Thanks guys. I was unaware that the later NA8's had a slightly different Gearbox.
Sent from my iPad using Tapatalk HD
