Re: Loosing power
Posted: Sat Apr 21, 2012 5:32 pm
1978sc wrote:Hi Guys
I have a 97 NA8. It has ITBs and an Adaptronic Ecu. I have an intermittent fault on the car. When it is hot occasionally it looses power, sometimes all power and sometimes half power. I have an 02 gauge in the car and when it is playing up the gauge goes from full lean to full rich and generally is backfiring as well. If you stop the car for a while it will drive normallay again. We have put a new throttle switch on and have also checked and tested the coil pack and fuel pumps. Anyone got any ideas as what to try next.
When you say the 02 gauge goes from full lean to full rich does it do this while the car is playing up, or does it go from normal (when the car is right) to rich (when the car runs rough), or is it erratic?
Woz
