rear g/box oil seal, does the tail shaft make the seal?
Jace
Postby Jace » Fri Apr 20, 2012 5:33 pm
box is currently on the floor ready to go back in, with a new clutch bolted up, rear main and g/box front oil seal installed.
when i pulled the tailshaft, a small amount of fluid came out of the center of the hollow stub of the shaft itself.
now i've drained and re-filled the gearbox oil, and as soon as the rear of the box is even 1cm off the ground, oil pours out.
i ran down and bought a new seal that appears to be different to the one that's in there.
the installed seal looks like this
is the tailshaft supposed to form the seal once installed? or is my rear oil seal just plain toast?
thanks!
- jace
wozzah1975
Re: rear g/box oil seal, does the tail shaft make the seal?
Postby wozzah1975 » Fri Apr 20, 2012 5:38 pm
Jace wrote:box is currently on the floor ready to go back in, with a new clutch bolted up, rear main and g/box front oil seal installed.
thanks!
- jace
Tail shaft seals it bud,
Woz
Beelzeboss
Postby Beelzeboss » Fri Apr 20, 2012 5:39 pm
Yeah, the tail shaft forms the seal. Without it all the oil will just run freely out the back of the gearbox.
Andrew
NA-6 2.5 KL V6
http://barberprecision.com.au/
Jace
Postby Jace » Fri Apr 20, 2012 5:43 pm
that seems really weird to me, but that's a relief!
thanks a bunch guys, i really appreciate it! :beer: :beer:
