Had a chat with the local exhaust specialist regarding my NB. I'm looking to give her a bit more if an aggressive note without making the car unpleasant to the driver. He's suggested replacing the rear muffler with a resonator. It seems like a reasonable way to go. Has anyone here done this ? Any views? I don't have the budget to put on a
mega-dollar rear system.
Nb8a Exhaust Mods
- Zcootz
Nb8a Exhaust Mods
With two laps to go then the action will begin, unless this is the action, which it is.
Murray Walker
Murray Walker
Re: Nb8a Exhaust Mods
Depending on the resonator he's referring to it will be different.
the muffler on my car is basically a resonator with a 2.25inch inlet and a 4.5 inch outlet.
It sounds great, but is rather noisy and does drone terribly on the highway.
Here's a video of it:
And here's one with the silencer in that chokes it down to a tiny exit:
- NitroDann
It drones because of the tip.
If it had a regular tip it would be GREATLY reduced.
Agree with the droning from the tip, I've got a cheap aftermarket 140C200 Megaflow muffler on the rear (only $100 locally)and it originally was fitted with a 3 inch (63mm to be exact)tail pipe. It sounded awesome, but going up the freeway you needed earplugs from the constant drone. Now I've got a 2.5 inch and the droning was reduced by at least 50%. Still sounds good, not quite as deep as before but much better than stock (which to me didn't have any real exhaust note at all).
Was: 1988 Corolla 4A-GE Twin Cam, 1991 Laser TX3, 1995 Peugeot 306 S16, 2003 Astra Sri Turbo, 2007 SP23 Lux
Now:1999 NB8A, 2011 Outlander VR-X
samx5 wrote:Agree with the droning from the tip, .....it originally was fitted with a 3 inch (63mm to be exact)tail pipe. .......
63mm IS 2.5", so you didnt change sizes????
Sorry, it was 63mm after it was changed.
- Vehicle: Non MX-5
puting a resonator in place of a muffler is the same as fitting a cannon. noisey!
if you what a bit more noise and note, then fit a more free flowing muffler.
if you still have the regular cat fitted, the exhasut will not be harsely noisey.
Users browsing this forum: No registered users and 112 guests
