Engine 1.6
myredmx5
Engine 1.6
Postby myredmx5 » Sun Apr 08, 2012 3:17 pm
Can anyone ID the arrowed part
project.r.racing
Re: Engine 1.6
Postby project.r.racing » Sun Apr 08, 2012 4:19 pm
An oil outlet.
Sean
Re: Engine 1.6
Postby Sean » Sun Apr 08, 2012 4:26 pm
project.r.racing wrote:An oil outlet.
I think he means inlet...
project.r.racing
Re: Engine 1.6
Postby project.r.racing » Sun Apr 08, 2012 7:43 pm
Nope I meant outlet. Since it is between the oil pump and filter. Why an outlet is there I wouldn't know.
Re: Engine 1.6
Postby NitroDann » Sun Apr 08, 2012 8:17 pm
No.
Its an oil return, an inlet, its often used to return oil from a turbocharger...
No.
Sean
Re: Engine 1.6
Postby Sean » Sun Apr 08, 2012 8:29 pm
Yep that's what I though.
It's painful to use as an oil return just due to locale.
Not sure such a simple bung cover would deal with oil under pressure too well.
Re: Engine 1.6
Postby NitroDann » Sun Apr 08, 2012 8:39 pm
Drilling and tapping underneath the a/c bracket ( :roll: ) on the setup I'm building now.
olboy
Re: Engine 1.6
Postby olboy » Sun Apr 08, 2012 9:59 pm
I tried use it to vent the block
I ran a hose through a catch tank
After 1 track day i had 2ltrs of oil in the tank
It was pumping heaps of oil out so I closed it up again
Re: Engine 1.6
Postby NitroDann » Sun Apr 08, 2012 10:01 pm
Be ok if you always ran oval tracks... backwards.
haha
noddi85
Re: Engine 1.6
Postby noddi85 » Sat May 19, 2012 1:55 pm
I know this is a old post but could it be used as a oil cooler return?
I'm looking at options to setup my oil cooler but also my catch can. As the head has two outlets not sure which one would be best.
Chris
Sometimes I wonder why i have different taste to others??? Then I realise its because Im not a sheep
Re: Engine 1.6
Postby NitroDann » Sat May 19, 2012 2:12 pm
Yeah it can be used as an anything return.
noddi85
Re: Engine 1.6
Postby noddi85 » Sat May 19, 2012 2:18 pm
What about a feed for it?
Any ideas?
Re: Engine 1.6
Postby NitroDann » Sat May 19, 2012 2:24 pm
A feed for what? use a sandwich plate.
Have a look in for sale, APU has a genuine works engineering oil cooler kit with everything you need,
noddi85
Re: Engine 1.6
Postby noddi85 » Sat May 19, 2012 2:28 pm
Cheers will do.
A feed for the cooler I ment.
Was just thinking of using what the engine has rather then a sandwich plate.
