Canola-based Motor Oils
Posted: Sun Apr 01, 2012 8:52 pm
I started using Woolies Home Brand canola oil as bar oil in the chainsaw a couple of seasons ago, mainly so I wasn't dumping litres of raw petroleum oil on the ground around the woodpile every year. It sort of helped that it was 1/4 the cost of normal bar oil.
Rather surprisingly the chain ran faster, quieter and much, much cooler on canola than on petroleum oil. Even better was the fact that chain and bar wear almost ceased.
Quick research seems to suggest that it would make better engine oil than premium synthetics too.
http://www.hort.purdue.edu/newcrop/ncnu02/v5-029.html
I've got an old Astina with a tired motor sitting in the shed. What do you reckon? Is it worth trying $10 worth from the cooking and oils section at the supermarket?
Canola-based motor oils have rapidly evolved into a competitive product. In terms of pricing, they are highly competitive with synthetic motor oils. They are also the most “environmentally friendly” of the motor oils available maintaining properties of non-toxicity and biodegradability. In terms of functionality, they have exceeded expectations by surpassing both conventional and synthetic oils in the tests conducted. As a low friction fluid, these tests indicate vegetable motor oils, or bio-oils, are a competitive product in modern engine applications.
A pleasant surprise has been the response of engines in terms of tailpipe and manifold gas emissions. The reductions in nitrous oxides, carbon monoxide, non-methane hydrocarbons, and hydrocarbons provide an easy and effective way to reduce air pollution. The value of these exhaust emissions has now become established and, in effect, may have more value than the oil itself. The impact of conversion to a bio-based motor oil for each million automobiles dríven 18,590,000,000 km per year (17,699 km per vehicle) would be staggering. Hydrocarbons from automotive exhaust would be reduced annually by 1,101 t; carbon monoxide would be reduced by 87,475 t; and nitrous oxides would be reduced by 1,416 t.
