Strange noise at low RPM
toddl1
Postby toddl1 » Wed Mar 28, 2012 11:58 pm
I've got this strange noise that occurs at low RPM, like below 1000RPM if I'm a little fast off the clutch and the revs drop I get this knocking noise coming from the engine bay. It actually sounds as if the engine is bumping against something. I've looked and I can't see any contact being made, or the engine moving around more than usual on the mounts.
I thought that it might be a bad engine mount, any other thoughts?
1989 Eunos Roadster
Steampunk
Re: Strange noise at low RPM
Postby Steampunk » Thu Mar 29, 2012 12:23 am
Do you know what pinging/detonation sounds like?
samx5
Postby samx5 » Thu Mar 29, 2012 9:44 am
Yes it may be getting pinging/detonation due to being under too much load. Try putting the car in 4th gear, drop to 40 km/hr and then try to accelerate, it may do it then also. Like a metallic 'rattling' sound. If the timing has been advanced and there is 91 octane petrol in the tank, it may be pinging/detonating and require 95 or 98 octane petrol. Easy thing to check first.
Was: 1988 Corolla 4A-GE Twin Cam, 1991 Laser TX3, 1995 Peugeot 306 S16, 2003 Astra Sri Turbo, 2007 SP23 Lux
Now:1999 NB8A, 2011 Outlander VR-X
myredmx5
Postby myredmx5 » Thu Mar 29, 2012 10:24 am
It could be the Hydraulic lifters.
Have you lifted the bonnet and played with the accelerator and listened for the noise?
