NA8 engine rebuild complete!
marty085
Postby marty085 » Thu Mar 22, 2012 8:55 pm
So I picked up my 94 NA8 today with freshly reconditioned engine along with all new hoses, clutch etc. etc. The whole thing basically.
I have dríven it about 15km so far, but all I can say is that it feels incredible. It feels like it just rolled off the factory floor. Can't believe how nice and smooth it feels. :mrgreen:
Spent the arvo putting in my NB8B seats and changed the fuel filter (this engine is gonna be the best-taken-care-of engine ever).
Also one of the engine mounts was sheared off and the other was nearly also, I reckon that would make a difference also.
Anyway, the point of this post is simply to say this.. if you're the owner of an older NA with a high-km engine and you're toying with the idea of getting your engine reconditioned, so far I reckon it's TOTALLY worth the money. Although looking back, my pre-rebuild engine must have been pretty poor condition so the difference I suppose depends on what your engine is like atm. I saw my old pistons and they had black carbon buildup all over them.
-Marty
Re: NA8 engine rebuild complete!
Postby Regie » Thu Mar 22, 2012 8:56 pm
Good to hear mate,
Hope to see you zooming around the local area!
Bizi
Postby Bizi » Fri Mar 23, 2012 8:10 am
Congrats, Marty! Any chance you can join us Sunday for the BreakFast Club or the 9AM version, to drive over Bells Line of Road and various hilly passes?
Hjt
Postby Hjt » Fri Mar 23, 2012 9:38 am
Happy for you mate , come Sunday...
BadBong
Postby BadBong » Fri Mar 23, 2012 10:42 am
I think he's already signed up for this Sunday since I'll be getting a lift right? RIGHT>?! :twisted:
*Just don't push it too hard yet... unless you can drive a good 500-1000kms in the next 2 days haha...
project.r.racing
Postby project.r.racing » Fri Mar 23, 2012 8:12 pm
rebuild or recondition? 2 very different things.
marty085
Postby marty085 » Fri Mar 23, 2012 8:32 pm
Yes you are right, I was just being lazy.
It was reconditioned including new pistons, rings, honed etc.
project.r.racing
Postby project.r.racing » Fri Mar 23, 2012 9:02 pm
that sounds more like a rebuild. but the freeling of better running must be the improvement in bore reconditioning. make me wanna do the same.
marty085
Postby marty085 » Fri Mar 23, 2012 9:21 pm
Hmmm well it was done by a reconditioning shop. They pulled it all apart obviously and machined everything and put in brand new pistons & rings, reconditioned the head, all new bearings on the crank and conrods. Everything I've read suggests that rebuild uses existing pistons and just puts new rings on. They said it was a full recondition to spec.
Postby NitroDann » Fri Mar 23, 2012 9:39 pm
Why are we arguing semantics?
marty085
Postby marty085 » Fri Mar 23, 2012 9:45 pm
Agreed. I don't care what's in a word, as long as my engine oil burning problems were solved and I get good engine performance for as long as possible :D putting this thread to bed!
wassup
Postby wassup » Fri Mar 23, 2012 11:48 pm
What's something like that cost?
1990 NA6
Civic Type R
cooper1896
Postby cooper1896 » Sat Mar 24, 2012 8:04 am
Was also interest to know.
Andrew Cooper
White Na8 Clubman
marty085
Postby marty085 » Sat Mar 24, 2012 9:17 am
Not cheap. R&R of the engine (remove and reinstall) by mechanic was $880.
Reconditioning was $2650 and took 3-5 days.
Timing belt kit from Mania for $300
Oem Clutch kit was $150 delivered from the States
Same as coolant hoses, around $150 delivered from states. Gen Maz.
Plus engine mounts $70 each from Mazda from memory? I forget exactly.
Various other bits and pieces (screw clamps rather than spring, gaskets, etc) for $180
Mechanic kept my redline tranny oil he reckons. Plugged the back? It wasn't that old.
Plus of course other fluids.
Plus GST so add 10% to labour.
I stuffed around with import engines which ended up losing me more than I care to mention in labour, freight and a wasted waterpump, I will never fark around with import engines again.
But I plan to keep this as my wkend car for a long time now so it should last. I had a new radiator 6months ago and the radiator place flushed it no charge.
If I had time to do some things myself I would. I would attempt the R&R with a borrowed hoist. But I work til 8.30-9pm most days and wkends are mostly spent resting or catching up with either my or my missus' family. But if u have time then go for it and save nearly a grand.
sailaholic
Postby sailaholic » Sat Mar 24, 2012 11:30 am
Sounds about right, who did it?
Torque team quoted me about 2300 for a balanced lightened (200 extra) over bore (50 extra) bottom end and assembly. I'd give them the engine, head off (had was already done) they'd give it back in the same condition.
