145,000kms original timing belt
I bought my car on 144'000ks and i've added about 600ks onto that. I asked the person i bought the car of if they did the 100,000k timing belt and she hadn't so now i really need to change it. I don't thing she had serviced it in a while so what exactly do i need to change so my car doesn't blow up. :O
Re: 145,000kms original timing belt
Timing belt kit with gaskets
Belts
Water pump
Oil, filters and fluid replacement
Basic 100km service.
Pretty tuff little motors.
Brake check etc
Good luck
Belts
Water pump
Brake check etc
Good luck
- JBT
Its a na8. Any idea roughly what it would cost?
- JBT
$1,000 +....depending on whether you do the work or you take it to a mechanic.
Ill have to take it to a mechanic
hopefully its not too much. I'm fine with $1500 if i have to.
- CQYD
might as well do the seals too while you are there, they are probably worn by now
- bootz
what seals? Crankshaft?
- JBT
toppertee wrote:Timing belt kit with gaskets
Belts
Water pump
Brake check etc
Good luck
x2. Fluid replacement should mean engine, diff, gearbox, brake, clutch AND coolant to give it all a nice fresh start for you.
Anyone recommend an oil or just what the mechanic has that's right for the car? I might be able to do oil myself. How hard is it?
- jules
- Guitar Hero
Don't forget timing belt tensioner and isn't there an idler bearing in there too? Been a loooong time.
Jules
Jules
- NitroDann
Muffler bearing mate, not 'idler'.
Timing belt invoice Gold coast Mazda done in Nov 2011 , all the bits, all the bucks,two pages.
http://imageshack.us/photo/my-images/839/gcmp2.pdf/
http://imageshack.us/photo/my-images/685/gcmp1.pdf/
- Russellb
- RIP Nov 2014
Basho wrote:Timing belt invoice Gold coast Mazda done in Nov 2011 , all the bits, all the bucks,two pages.
Thats what we charge in Canberra but We do ALL the water hoses at the same Time
maybe we are to cheep
My ClubmanRebuild
MX5 SE Rally car is HERE
