Oil Leak issue
project.r.racing
Re: Oil Leak issue
Postby project.r.racing » Fri Feb 24, 2012 8:21 pm
too difficult to tell from that picture. could be any of those. as can only see the bottom of the enigne. could be coming from anywhere above that.
mitch_f1
Re: Oil Leak issue
Postby mitch_f1 » Sun Apr 08, 2012 10:59 am
See if you can trace it further up. If you can't find any oil further up just dump some RTV gasket on the sump seam, and see how you go. Replacing the sump gasket is worth more pain than putting up with a couple of oil drips.
