mrpham wrote:NitroDann wrote:There isnt enough room in an MX5 engine bay for useful sized ITBs at all if they are straight. And Ive never seen curved ones in an MX5 bay.
lol
I borrowed the runners (curved) from my friend's M3, initial measurements say that they will fit. So I'll be playing around with them when the time comes, my super accurate ass-dyno should be able to give some numbers about extra length but curved runners.
As with any ram tube, regardless of length, the most important thing is that the air around the entry be as undisturbed as possible. On most cars the length of the tubes is limited by the room you have to fit them, so in most cases it's a compromise. You are far better off with a ram tube thats slightly shorter than in needs to be to get undisturbed air than you are finding the optimum length and having the entry of the ram tube compromised.
Angled runners are not ideal, and in most cases you're better off with the angle of the runners correct in relation to the port, rather than finding an ideal length with an angled runner. You'll find that more than likely the M3 runners are designed to work with the M3 inlet port and will be angled to suit. They may not work on your engine as well.
The shape of the entry of the ram tube is also super important, there are some shockers out there.
As long as you're dynoing it in the engine bay, or simulating it fitted thats fine. I love mucking around with this sort of stuff
Woz
