Larini exhaust dealers?
username
Postby username » Wed Feb 08, 2012 1:11 pm
So my dads just put a deposit down on a NC and provided it passes a RACV inspection he shall be picking it up rather soon. At first he said it will stay stock, but after test driving it and seeing it in person he's changed his mind; he now wants to lower it a inch or two and put some sort of exhaust on. We've been looking at youtube videos to find the best sounding one and Larini seems to be a winner there. Only problem is they're in the UK. Are there any distributors here in Aus? I imagine shipping something of that size and weight from the UK wont be cheap at all
"signatures - a good place for a list of your cars modifications" -Jace
Re: Larini exhaust dealers?
Postby 93_Clubman » Wed Feb 08, 2012 1:49 pm
Can't help ref Larini dealer in Aust - indeed shipping from UK won't be cheap, but at least the AU$-GBP exchange rate is good for us.
If he's interested in a bit more power, there's an easy 20rwkw to be had on the NC:
Charlie Brown wrote:Best bang for your buck is without doubt a set of headers. And yes dyno’s are not the be all and end all but my car registered 91.6rwkW standard and 105rwkW with the headers. Cost is about $555 landed, snail mail from Goodwin Racing. http://www.good-win-racing.com/Mazda-Pe ... haust.html
Cold air intakes for the NC, in my opinion, are a waste of money. The standard intake sits horizontally in the nose of the NC and takes in cold air without modification.
I have a Cobalt CAI fitted, cost was about $140 delivered including filter when I got mine it’s slightly dearer now. http://www.miatamania.com/Shop/ViewProd ... exID=73664
The Cobalt CAI is the same length as the stock intake but sits vertically with the intake behind the lower slot in the nose. The K& N panel filter has the advantage that you can wash it clean, which you do often as the CAI picks up sand and bugs easily.
I noticed no difference when I fitted the CAI and there is no additional intake noise. The AEM / Mazdaspeed (about $360 landed, snail mail from Goodwin Racing) sits diagonally across the nose, its longer than standard and may have a minimal increase in torque at lower revs. Chris has dynoed a number of different CAI’s on his race NC’s and only picked up 1kW.
Mufflers. A word of warning. If you fit headers there is only one muffler to get and that’s the Goodwin ‘Q’ (cost $836). Any other will be way too loud. I’ve tried 5zigen, and the Roadstersport with baffles in and both will have you defected and your neighbours chasing you down the street trying to do you some injury.
Also besides the overwhelming loud note you have drone which kills the pleasure of driving even with a loud exhaust note. I think the note the stock muffler gives with the headers is fine, the main reason I wanted to change was a decrease in weight which would eliminate me having to swap mufflers at the track.
Performance wise Goodwin has some figures on his site about the development of the mufflers which is a good read. If you believe the figures you look at about a 4rwkW gain. A new mid pipe (cost $643) around another 2 rwkW.
So summarising a set of headers for $555 will get you around 13rwkW.
Add an AEM intake, a mid pipe and a Q muffler for $1839 and you get another 7rwkW. Pretty easy to see where you need to spend your money.
viewtopic.php?f=29&t=49533
Postby bruce » Wed Feb 08, 2012 1:51 pm
http://www.larinisystems.com/dealers/be ... /australia
Google is useful....
Problem is, it might be cheaper to import one than buy locally.
bensale
Postby bensale » Wed Feb 08, 2012 2:29 pm
These guys will be able to get you in a Larini exhaust with warranty etc.
http://www.bestexhaust.com.au
www.othersideproductions.com
