New Clutch = No Gears
Posted: Mon Jan 23, 2012 12:27 pm
Hi Guys,
Whacked a new clutch and flywheel in over the weekend but sadly now I can't select gears while the engine is running.
I put in a new slave cylinder as the old one looked quite scummy. Bled it to within an inch of its life. The slave cylinder piston is moving the clutch actuator lever about 3/4" for a full pump on the pedal. It just didn't seem like enough for me. On a hunch I hooked up a ratchet strap to the lever and cranked it up. Where the piston would be at 1 1/4" I found that I did indeed have a clutch.
If I take the ratchet strap to 1" and then use the clutch pedal I actually have a working clutch but it's somewhat impractical to have a ratchet strap hanging under the car.
If I ratchet to 1" then chock the pedal with a piece of wood, the slave will hold its position. I can then pump the pedal and keep it there however, if I let off the clutch completely there's a big woosh of fluid and the lever compresses the slave down to the hilt.
All I can think is that the master is rooted and I'm not getting enough piston from one pedal's worth of clutch.
How far should the piston travel? is 1 1/4" of travel too much?
I was pretty careful putting the clutch in, and as I said it actually works fine if you can get it to the friction point.
Thanks in advance for the help and advice.
Clancy
Edit: I put in an Xtreme HD Clutch and Lightweight Chomoly Flywheel if that matters. (Local shop did em for $600 the pair - cheering, well I will be when they work).
Clancy
