Help - Clutch Failure & Squealing Noises
daffyflyer
Postby daffyflyer » Sun Jan 15, 2012 8:02 pm
So, a little clutch problem has cropped up as of this afternoon - when I depress the clutch, it makes horrid metal on metal squealing noises and attempts to stall the car.
It makes the same noises and will STILL stall the car, even if its in neutral.
I managed to get home, and on the way home the noise has gotten quieter, and doesn't quite drag the car down to a stall now, but clearly something is amiss.
Everything seems hydraulically fine, although there was a brief moment of no clutch feel, which quickly went away, car has approx 20,000km old slave cylinder, braided line, master cylinder and clutch plate.
Any thoughts on what this could be? I'm willing to pull a gearbox this weekend if need be, but would like a guess of what parts I might need, as I need the car running to go to Tassie the week after.
Developing a Car Industry Game - Visit www.automationgame.com
White 1994 MX5 Clubman - Carco Built NA Motor - 101kw ATW @ 7500rpm
JBT
Re: Help - Clutch Failure & Squealing Noises
Postby JBT » Sun Jan 15, 2012 8:05 pm
Could be the spigot bearing (centre of the flywheel) failing. They can make some horrible noises.
project.r.racing
Postby project.r.racing » Sun Jan 15, 2012 8:14 pm
I'd agree.
Russellb
RIP Nov 2014
Postby Russellb » Mon Jan 16, 2012 9:44 am
Sounds like the release bearing has seized. this may have damage the pressure plate you wont really know till the box is out
My ClubmanRebuild
MX5 SE Rally car is HERE :)
JBT
Postby JBT » Mon Jan 16, 2012 10:52 am
Good point, it might have disintegrated. Although it (and the spigot bearing) should have been replaced when the clutch plate was replaced 20,000km ago.
Russellb
RIP Nov 2014
Postby Russellb » Mon Jan 16, 2012 11:41 am
JBT wrote:Good point, it might have disintegrated. Although it (and the spigot bearing) should have been replaced when the clutch plate was replaced 20,000km ago.
The plate was only replaced because it was soaking in oil from an oil leak.
Ask Daffyflyer about the oil leak.
My ClubmanRebuild
