LUMPY
slimx
LUMPY
Postby slimx » Wed Jan 11, 2012 5:13 am
I have a VVT model NB
And im looking for LUMPY CAMS
STAGE 2 - STAGE 3
I am aware that lumpy cams are only good for higher RPM im only getting it for the "rotary-like" sound. And im willing to put up with the cold start issues :)
WHERE DO I LOOK? VVT seems so limited when it comes to cams. I've found NONE
If cams are no good.. How else can i get a TAD more .. power + ROTARY sound. Without spending 10+k on a rotary conversion
elitee
Re: LUMPY
Postby elitee » Wed Jan 11, 2012 6:21 am
Itbs?
Re: LUMPY
Postby manga_blue » Wed Jan 11, 2012 4:23 pm
The only Maruha one is the VVT version of the F-CAM, which is not very lumpy at all.
http://www.maruhamotors.co.jp/miata/parts/vvtfcam.html
But then again, it's the only cam upgrade that I've heard of for VVT engines.
Re: LUMPY
Postby NitroDann » Wed Jan 11, 2012 4:29 pm
Get a non vvt head. Run whatever cams you want.
Or talk to wazzah1975 on this forum about a custom set of vvt cams.
Steampunk
Re: LUMPY
Postby Steampunk » Wed Jan 11, 2012 8:02 pm
Hey what happened to HKS_Kansei's reply?, he had the best answer!
greenMachine
Re: LUMPY
Postby greenMachine » Wed Jan 11, 2012 9:14 pm
slimx wrote:... And im looking for LUMPY CAMS
... im only getting it for the "rotary-like" sound.
You won't fool anyone, the GM ran big cams on the stock computer for a while, until I got the E8, and they don't have much similarity at all.
Are you sure you have bought the right car for you? If you want a rotary, buy a rotary.
:mrgreen:
slimx
Re: LUMPY
Postby slimx » Wed Jan 11, 2012 9:27 pm
Not getting
It to fool people stop trying to make assumptions.
Answer the question or piss off.
I want it for me. Because i like the sound but hate the reliability.
Re: LUMPY
Postby NitroDann » Wed Jan 11, 2012 9:39 pm
hate the reliability of what? Big cams? Get a clue.
dann
Re: LUMPY
Postby hks_kansei » Wed Jan 11, 2012 10:06 pm
1red5 wrote:Hey what happened to HKS_Kansei's reply?, he had the best answer!
I'm not quite sure.
I never recieved a PM or anything saying my post was insulting, personally I didn't think it was that bad.
Perhaps when a person buys some advertising space it comes with a free piece of preferential treatment.
Edit:
to make sure this post remains on topic, my original comment was quite valid.
Selim wanted the noise of a lumpy idle. Removing a plug lead will provide a lumpy idle.
I fail to see how something said in jest (as MANY comments are on this forum, but as they are to non sponsors they remain un-deleted) can be considered offensive?
sailaholic
Re: LUMPY
Postby sailaholic » Wed Jan 11, 2012 10:08 pm
Dann, I think he meant the reliability of a rotor.
Could just get your existing cams reground.
Hjt
Re: LUMPY
Postby Hjt » Thu Jan 12, 2012 12:33 am
You can't buy brains unfortunately.
Sure this post will be deleted, but it will also be seen prior.
Re: LUMPY
Postby Okibi » Thu Jan 12, 2012 2:16 am
hks_kansei wrote:I'm not quite sure....
I never saw it, i'm guessing it broke the forum rules, if there's a problem PM me with what you wrote.
username
Re: LUMPY
Postby username » Thu Jan 12, 2012 6:47 am
Have you checked out integral cams?
http://www.integralcams.com/miata.htm
"signatures - a good place for a list of your cars modifications" -Jace
Basho
Re: LUMPY
Postby Basho » Thu Jan 12, 2012 7:44 am
slimx wrote:I have a VVT model NB
And im looking for LUMPY CAMS STAGE 2 - STAGE 3
WHERE DO I LOOK? VVT seems so limited when it comes to cams. I've found NONE------
This post has to be a pess take , surely no-one can take this as serious question ? :lol:
slimx
Re: LUMPY
Postby slimx » Thu Jan 12, 2012 3:45 pm
Its a completely normal and sensible question that only requires an answer, not stupid remarks or pointless reply's all it needs is answers.
Yes Dann i ment ROTARY reliability. They say if u look after it they dont die, but i have many friends who STILL run into problems even after OVER-doing the looking-after
Your reply stupid HKS as it didnt answer my question does disconnecting your spark plug lead give u more power? No. U failed to answer the question. I know i can remove one spark plug lead. Its just common sense. Stupid Remark and it got deleted.. i dont see why your complaining.
That integral cams.. site doesnt seem to be loading up maybe its temporarily down.. ill give it another try later on.
EDIT: been googling around they seem to be my best bet. Anyone with VVT goes to them and "Fuji"
Regrounding cams ill have to do a little more research .. Find a few places and get some quotes. thanks.
edit: rang 4 places in 10min they all told me "VVT = stay away" one place recommended changing the head as nitrodann said. Then i can go crazy.. with that stuff.
