New Intake , weird noise. Thoughts?
Hey everyone.
I just received and installed my new DDMWorks Stage 2 Intake today. When I turn the car on there is a noticeable high pitch whine coming from the air filter area. It is noticeable when just sitting at idle as well as when on the move. The intake uses a K&N pod filter, i havent dríven a car with a pod filter before. Do they all make this kind of noise? (i doubt it). Any thoughts on what could be the cause on of the noise? The filter and box do slightly rub on what I believe to be the AC lines.
If anyone has any ideas on what the noise could be or how to fix it, that would be greatly appreciated.
Here is a link to what the intake looks like when installed>>>>
viewtopic.php?f=29&t=45248&hilit=mx5+factory+CAI
Re: New Intake , weird noise. Thoughts?
Air leak????
went and adjusted/tightened all the seals and clamps. Hasnt made a difference. My gut feeling is the area where the pod filter attatches to the tubing. Due to the AC lines the filter is on a slight angle but I Think ive got it on as good as it gonna go.
It does sound like a bit of an air leak, although I have had a message from a fellow Intake fan and he feels that that is the sound of an intake. Im Not 100% convinced, ill still keep an eye on it.
Any other suggestions are most welcome.
- Regie
- Vehicle: NC - V8
I had that intake on my nb
Did you install the line from the PVC valve on the rocker cover?
Apart from that it is a rather noisy intake....sounds awesome though
Regie wrote:I had that intake on my nb
If your talking about the rubber line that attaches into the centre of the polished intake pipe then yes I did.
- Regie
- Vehicle: NC - V8
shake and bake wrote:Regie wrote:I had that intake on my nb
yep thats the one
acually i didnt read the first post properly...the whine is normal...mine did it
I was looking at these intakes earlier today actually but now I have read this I'm not sure I want one anymore...sounds plain unpleasant!!
- Regie
- Vehicle: NC - V8
deviant wrote:I was looking at these intakes earlier today actually but now I have read this I'm not sure I want one anymore...sounds plain unpleasant!!
The are an awesome intake though.....tops sounding on WOT
- toymx5
Hey shake and bake,
There should not be a whine, that's my car in your link for the photos and mine doesn't whine at all. Something mustn't be fitted properly.
Good luck with it.
Toymx5
Good luck with it.
Toymx5
My little 'Toy' thinks she's actually a Ferrari !!
Took off the Helmholz chamber, now noisy intake.......hmmm
Silver Nomad
2002 NB8C
2002 NB8C
toymx5 you have a pm.
Bloody Helmholz chamber!!
Have been doing a bit of research. Seems like most K&N filters create this noise for various reasons. I even saw a vid on facetube of a dodge who had put a K&N filter on and I could hear the exact same noise that im talking about. Maybe ill experiiment with some different filters. Has anyone who runs a K&N filter noticed this sound?
