engine removal question.
plohl
Postby plohl » Wed Dec 28, 2011 9:49 am
Hi,
Can the engine be removed with the rear of the ppf still attached to the diff? I am having trouble tracking down an M14x1.5 to remove the diff sleave, thus stopping me from removing the ppf.
plohl
Re: engine removal question.
Postby NitroDann » Wed Dec 28, 2011 10:06 am
Yes I do this every time.
But why do you need a m14 bolt to remove the ppf from the diff?
JBT
Postby JBT » Wed Dec 28, 2011 10:54 am
I recall some reference to that in the Haynes manual - it is incorrect, just undo the bolts. However, you do not need to disconnect the PPF at the diff to remove the engine.
geofiz
Postby geofiz » Wed Dec 28, 2011 11:19 am
The diff sleeve can sometimes be difficult to remove, but when it is stuck I have removed the mounting block on the side of the diff carrier, which then enavls you to remove the ppf.
NB8A - mostly stock for now
Postby NitroDann » Wed Dec 28, 2011 11:25 am
There MUST be a correct way to assemble and dissassemble the ppf from the diff, but I always just use a crowbar and level it on and off fully assembled.
plohl
Postby plohl » Wed Dec 28, 2011 2:12 pm
yeah, the bolt is to remove the sleeve. Its pretty stuck. I dont need to take it off so i'll just rip the enigne out.
happy days.
Thanks everybody!
plohl
