Idle Speed Control Valve - Faults
Posted: Sat Nov 26, 2011 12:19 pm
2nd time this issue has occurred.
Get in car, start, no power windows, turn off, on, windows are back. Now the idle is 'off'. You drive along and as you break for the lights the revs hold at 1700 before dropping to tickover. As you sit there, they will suddenly go up, then drop down.
Replaced the Throttle body/ISCV unit last year after this happened and has been fine till now.
So, I detached the lead to the ISCV unit and turned the idle screw till the revs sat as per normal.
The car runs normally, although the idle is not as smooth, the revs are consistent, it just doesn't have a smoothness about it on idle.
There seems to be no difference on the road at speed.
What is the downside of running the car without the ISCV connected?
