MX5 Oil Seal Sizes
Posted: Thu Nov 10, 2011 10:47 pm
by spikes
Was hoping this would help somebody when they go to change their front cam seals and front crank seals. Go to any bolts and bearings shop and they will sell you these seals for roughly $4 each compared to $11 from repco/bursons/or even more expensive; the stealership
Cams - 34 x 48 x 7
Front Crank - 38.5 x 50.5 x 7
I think this thread would be really useful if somebody was changing their rear main seal, tranny seals and CAS O-Ring seals to measure/read the markings.
I searched everywhere over various mx5 forums and wasn't able to find these measurements
Re: MX5 Oil Seal Sizes
Posted: Thu Nov 10, 2011 11:32 pm
by toppertee
Nice one
Posted: Fri Nov 11, 2011 12:05 pm
by Mr Morlock
normally seals like bearings have part numbers. You can guarantee all products are not made equal. Rubber specs are not all the same and nor are tolerances etc. Experts can comment but quite often items are still imperial ie mm simply hard converted- not sure if this applies to these seals. One thing that is apparent is the cross reference catalogs for seals and bearings etc are often incorrect and some mechanics remove the item before ordering it- so you can often get the wrong item.
Posted: Mon Jul 11, 2016 11:39 am
by 93_Clubman
NA B6 & BP motor CAS o-ring:
Model #: BS222
Part #: 0509 7704
1.75" OD (44mm)
1.5" ID (37mm)
1/8" section (3mm)
NA & NB B6 & BP motor rear crankshaft seal:
Part #: BP05-11-312
100mm OD
83mm ID
9mm width
Alt Part #: 403058S
Alt Part #: SKU158623
Alt Part #: LYO 83921
Type: HTCL
