NA LSD?
25GTV
NA LSD?
Postby 25GTV » Mon Oct 10, 2011 9:40 pm
Hey guys I have a 1991 1.6 MX5. Its an import 'roadster model'
Its has a lsd but I want to upgrade to the NB rear end.
Any idea what type of lsd I have and what do they sell for? It works very well :)
Any info is much appreciated.
Re: NA LSD?
Postby NitroDann » Mon Oct 10, 2011 9:46 pm
Its just a viscous 4.3 diff like everyone elses. Id be amazed if it worked really well. Even new they are rubbish.
If you are lucky someone will pay 150 for it. or you can leave it on the site at 300 and wait 6 months. Thats usually how they go.
25GTV
Re: NA LSD?
Postby 25GTV » Mon Oct 10, 2011 10:56 pm
Ive had viscous diffs before and its definitely not a viscous. Ive jacked it up and spun the wheels etc it must be a clutch or torsen lsd...
Re: NA LSD?
Postby NitroDann » Mon Oct 10, 2011 11:35 pm
When you jack up a torsen and spin the wheels they just act like a regular open diff.
Is it a 1.6 diff or 1.8? Are you sure?
25GTV
Re: NA LSD?
Postby 25GTV » Tue Oct 11, 2011 10:46 am
When i jack it up the wheels act like a 2 way clutch pack lsd... its a 1.6 car and looks like a 1.6 diff housing/shafts...
Re: NA LSD?
Postby NitroDann » Tue Oct 11, 2011 10:59 am
Cusco or something then.
Probably worth 800 odd complete.
GLWS
25GTV
Re: NA LSD?
Postby 25GTV » Tue Oct 11, 2011 2:47 pm
Thanks for the info Dann!
I think Ill open it up to check.
Jace
Re: NA LSD?
Postby Jace » Tue Oct 11, 2011 7:34 pm
Where are you located OP? I might be interested even if it's an OEM one.
Si.G
Re: NA LSD?
Postby Si.G » Tue Oct 18, 2011 11:44 pm
FYI - with my viscous diff, if you jack up the back and turn one wheel the other wheel goes the same way, so spinning a wheel is not a great test, either that or mine is knackered :)
Si.
NA6 B6T
gussy
Re: NA LSD?
Postby gussy » Wed Oct 19, 2011 9:50 pm
Most viscous diffs were knackered about 12k's from the factory floor. :lol:
